Create a Custom Library
Hello, I have a question about libraries. I've created some basic cells that I need to integrate into another one, but unfortunately, I can't seem to do that. I'm thinking that creating a library might be a good idea, but I don't know how to create a custom library. So, my question is: How do I create my own library? Do I need to write a script for this?
Thank you for your consideration and for taking the time to help me. I'm feeling quite frustrated.   ![]()
it is explained here:
https://www.klayout.de/doc-qt5/about/about_libraries.html
Okay, I saw that it explains where I need to install my libraries, which is in "~/.klayout/libraries". But the main question is: How do I install a library?
I tried putting all my GDS files in "~/.klayout/libraries," but I can only use one GDS file. When I attempt to place these files in subdirectories, nothing seems to work. I must have overlooked something, but I don't know what it is.
1) sub folders don't seem to work
2) each GDS/OAS file needs to have a unique library name (LIBNAME)
-- deleted --
I did this but it doesn't work, I tried many other combinations.
Can you give me a real exemple ? thanks
kinds regards
when I put all my gds files in "libraries" its work but only with one component
Hi CMeyer
As tomas2004 mensioned, each file needs to have a unique LIB name, otherwise KLayout will only show one component.
The LIB name can be modified through save file dialog.
Thanks it's working, it will be the mess with all my companants but it works.
