Dear Forum, what does the "freeze" option in "menu --> view --> navigator --> options" do? I couldn't find any doc about it~
Hi halfmoonhalf,
It freezes the layer as well as cell display status.
If you enables the freeze function, the layer visibility in navigator will not change along with the main view window, so as the cells.
freeze
Reading the headline I briefly though that is a weird bug ... @RawrRanger thanks for that explanation!
thanks both gurus for commenting! thank you very much!
Hi halfmoonhalf,
If you enables the
freezefunction, the layer visibility in navigator will not change along with the main view window, so as the cells.Reading the headline I briefly though that is a weird bug ... @RawrRanger thanks for that explanation!
