Dear all,
I want to check if cut_box is not empty, i will save cut_box to image
cut_box = db.DBox(sub_x2, sub_y2, sub_x1, sub_y1)
if cut_box is empty:
print("box is empty")
else:
print("box is not empty")
layout_view.save_image_with_options(sub_image_path, pixel_size, pixel_size, 0, 0, 0, cut_box, False)
Here is an example of cut_box is empty images (just a full white image)
Thanks and best regard,
HieuND
Hi hieund,
begin_shapes_rec_overlappingfunction returns a list of object that overlapped with given box.Thank Mr @RawrRanger,
I try to using shapeInRange function, but this function always return True in every cut_box, May I wrong anything ?
Hi hieund,
begin_shapes_rec_overlappingis not suitable for filtering shapes with holes,if shapes with holes is overlapped with the box this function will still returns True,
so additional check is using
polygon.touchesis required.rsi.shape().polygon.transformed(rsi.trans()).to_dtype(unit).touches(detectBox)Another thing is this function does not check the layer visibility, so hidden layer will requires additional check.
following test case using three cut box 1~3 corrosbonded to the three white boxes placed in left to rignt order.
without
polygon.touchescheck, the output for L0/0 (bule) will beTrue, True, Falsewith
polygon.touchesadded, the output for L0/0 (bule) will beFalse, True, FalseThanks you, Mr @RawrRanger , it works for me !!
