yes it is. File->Setup, page Application/Key Bindings. Choose the item for which you want to install a shortcut, enter the desired key into the shortcut box right to the item list and hit "Ok".
Can a key be bound to a chain of singlet commands, short of
"macro-izing", by some syntax (like command;command )?
I also recall there was a particular binding which was "hard"
while others were "soft" (user can change). Don't remember
which, why or why I cared at one point. My question (#3)
there is, is that still so or is everything up for grabs.
OK, #4 - is there a facility for saving out and reading back
(onstartup, by klayoutrc?) a customized bindkey definition
file?
Hi Matthias, the "Customize Menu" tool is an awesome feature. Is there an option for switching the type of ruler? Ideally I could assign a different shortcut/hotkey for Ruler, Cross, Box, etc.
Ruler and annotation currently does not have a shortcut setting avaliable in the customize menu page,
but we can always acess the menu items by macro and bind the macro to a hotkey like my previous comment.
For example we use edit_menu.mode_menu.ruler.ruler_template_{i} to set current ruler type (Ruler, Box, measure..., I starts from 1 to customized ruler template counts)
After set and template, call with @toolbar.ruler to trigger measure function.
In following example, the 2nd ruler template is setted as active ruler, in my case is a diagnal measurement, it'll not always be the same accross different machine.
Paset following codes and change the 2 number in last line and bind the macro to keys, repeat this until you got all the template/key~~~~ set.
def activateRuler(i = 1):
menu = pya.Application.instance().main_window().instance().menu()
menu.action(f"edit_menu.mode_menu.ruler.ruler_template_{i}").trigger()
menu.action("@toolbar.ruler").trigger()
activateRuler(2)
# change this number and bind the script to different hot key
# repeat this to map keys to different ruler type
Instead of triggering a specific action, you can also use the canonical ways - i.e. "set_config" and "switch_mode". This may be a slightly more portable:
Hi Shirly,
"Key Bindings" no longer exists as of 2023, using version 0.28.7
what is the new location?
Hi nmz787_intel
In newer version, the kotkey can be set in customiz menu tab
... and it is called "Customize Menu" now since you can turn off menu entries
I have a question about key-bindings. Maybe two.
file?
Hi dick_freebird
macro can be bind to hot key throuth macro properties setting page (wrench icon).
key bind can be set at
default key short cutoptionFor change hot key binding using a script that bind to a hot key,
here's an example of saving hot key and load back
Exactly
 Thanks @RawrRanger!
HI 14darcia,
For example we use
edit_menu.mode_menu.ruler.ruler_template_{i}to set current ruler type (Ruler, Box, measure..., I starts from 1 to customized ruler template counts)After set and template, call with
@toolbar.rulerto trigger measure function.In following example, the 2nd ruler template is setted as active ruler, in my case is a diagnal measurement, it'll not always be the same accross different machine.
2number in last line and bind the macro to keys, repeat this until you got all the template/key~~~~ set.Very good, thanks @RawRanger!
