Value of begin_shapes_rec variable changes if new shapes added to cell.
Dear Mattias
I am saving the value of begin_shapes_rec into the following variable "dies_ol":
dies_ol = pya.Region(cell.begin_shapes_rec( layer_ol ))
After this I add new shapes in "layer_ol" into the cell.
This changes the value contained in dies_ol variable.
Is this expected or is this a new behaviour ?
Because in the past I think Klayout would keep the original variable value.
Maybe I should not use begin_shapes_rec this way. in this case I wish you could letme know what should I use insteadt.
I am attaching the input gds and the script to reproduce this.
Please let me know
Thank you in advance
Best regards
Giovanni
  • Hi Giovanni,
    yes, that is intended.
    Actually, when you create a Region with a recursive shape iterator, it becomes a special kind of Region called an "original layer region". It is not a replica of the layer, but represents the actual layer inside the source layout. This feature is preventing unnecessary and expensive copies. Also, such a region remains hierarchical, hence saving memory.
    In order to "freeze" a Region, you can use "flatten". But beware, this will do what it says and may explode your hierarchy.
    For example, this code reproduces your problem:
    ly = pya.Layout()
    l1 = ly.layer(1, 0)
    top = ly.create_cell("TOP")
    top.shapes(l1).insert(pya.Box(0, 0, 100, 100))
    r1 = pya.Region(top.begin_shapes_rec(l1))
    top.shapes(l1).insert(pya.Box(200, 0, 300, 100))
    r2 = pya.Region(top.begin_shapes_rec(l1))
    print(r1)
    print(r2)
    As you experienced, it will print the same shapes, although the second shape was added after the region 1 was created:
    (0,0;0,100;100,100;100,0);(200,0;200,100;300,100;300,0)
    With "flatten", the copy is frozen:
    ly = pya.Layout()
    l1 = ly.layer(1, 0)
    r1 = pya.Region(top.begin_shapes_rec(l1)).flatten()
    r2 = pya.Region(top.begin_shapes_rec(l1)).flatten()
    print(r1)
    print(r2)
    and it prints:
  • Thank you Matthias for the detailed explanation.
    I wil change my code and make shure that I add .flatten() when I need to freeze the content of the region.
    Thank you again
    Best regards
    Giovanni
