As a newcomer to using the KLayout Design Rule Checker , I have observed that during width checks, the DRC reports errors for only instances of identical structures, while other  identical structures are not flagged. I am unsure whether this behavior is an inherent characteristic of the DRC tool or if there is an underlying issue in my design setup. Could you please explain why this occurs and whether it reflects a standard behavior of the DRC? As you can see in the image below, I'm not sure if you can see it.Thank you very much for your assistance!
@Matthias
Hello!I'm sorry to disturb you, but I noticed that no one has responded to me. May I kindly ask if you could help address my inquiry? Thank you so much!
Off the cuff, I wonder whether there is a "please,
no more!" error-display-limit hard coded, or if you
are lucky some setting (I see such things in
simulators' options, "maxwarn", "maxerr" like.
Maybe there is a built in control variable where
you could assert higher in your "deck".
I have zero DRC skills with klayout but that is
what pops to my forebrain.
@dbsdyhxx Some more details are helpful. Are you using "deep" mode? In that case, the errors will be reported once inside the cell if possible.
I will not be able to debug the problem without a test case. Rushing me won't change anything about that.
@dick_freebird
Thank you for your reply. I noticed that the program didn't throw any errors during execution, but there's a message saying "Not all entries are shown!" in the Marker Database Browser window after it finishes. I wonder if this might be related to the problem?
@Matthias
Thank you for your reply. I apologize for bothering you again. Below is my test case:
negative_angles = FE_Core.corners(-180..-100)
positive_angles = FE_Core.corners(100..180)
FE_Core_angle = negative_angles + positive_angles
FE_Core_angle.output("WG.01","Forbidden, WG.01: NITWG Angle < 80°")
@dbsdyhxx I am sorry. This is not a test case. This is just four lines - no layout file or the rest of the code.
A proper test case is a complete, executable script and a layout file.
At least, maybe you can answer my question above: are you using deep mode?
I can't give any advice with so little information.
Here is my test case:
(see attached file)
Script:
All errors are shown (Linux, Ubuntu 24.04). Version is 0.30.1.
Is there or is not, an upper limit default to
number of errors displayed? And was the
test case of sufficient size, to expose that?
Hi @dick_freebird,
you're right! ... I forgot to mention that.
You can set the limit to a high value, but if there are may violations (>10M), it's better to write the markers to a layout layer. You will not browse single markers in that case.
