Hi @SRF,
The current macOS
build4mac.pybuild system does not officially support Monterey.However, I hope it still works.
Kazzz-S
Edit 2025-02-23:
./build4mac.py -q qt5macports -r mp33 -p mp312build command (Fully MacPorts-flavored build), editmacbuild/build4mac_env.pyas below.Hi @SRF,
Kazzz-S
Hi @SRF,
I recently upgraded my development environment to
Sequoia 15.5 + Xcode 16.4 + VMware Fusion 13.6.3. See this ticket.I also noticed that the view count of this post increases gradually.
To reconfirm again that the source code build in Monterey is still possible, I attempted the two builds for
KLayout 0.30.2with the latest MacPorts packages.I uploaded two DMGs here for your reference.
Kazzz-S
I've noticed that the number of views for this post is still gradually increasing.
KLayout 0.30.3with the latest MacPorts packages.I uploaded two DMGs here for the community's reference.
Kazzz-S
I have made another attempt to build version
0.30.4on macOS Monterey (Intel).I have uploaded two DMGs for the community's reference, which you can find here.
Unfortunately, the latest macOS version,
Tahoe, no longer supports my 13" Intel MacBook Pro (2019 model).The machine's life is also nearing its end. :-(
Kazzz-S
