I have been using this fantastic software for a couple of years now. Well done to everyone involved.
Since the last Ubuntu upgrade, I have been unable to install KLayout without trouble (mainly because of the libruby1.9.1 dependency). Apparently, later versions are not supported. Anyway, I ended up successfully building the package from source but have been unable to save my desired configurations. For instance, when the application starts I change the background colour to a dark one, then close and re-open the application and all the settings return to their default values.
I thought this might have something to do with my building process. So, I went to a great trouble to install libruby1.9.1 and re-installed from deb package (don't know how to uninstall the built package) but the problem still persist.
Any idea?
Many thanks
Taha
Hi Taha,
thanks for your feedback :-)
Building from source is not quite unusual on Linux. I am using Ubuntu myself, but I have not upgraded to 16 yet. I actively support 12 and 14. For other version and distributions there is the build script.
If the application runs there is not much left that can go wrong. I assume the configuration problem has a different reason.
Technically, KLayout stores the configuration within a file called "klayoutrc" inside
~/.klayout. When you exit the application, this file will get updated. Since you cannot restore the configuration, I assume that something is wrong with that. For example:For debugging, you can try to use an explicit config file path on the command line with the -c option:
klayout -c ~/your_config_file.cfg
One of these things should make it work.
