I found this thread and I was trying to re-create the instance hovering effect, similar to the one from the button that creates the pcell instances.
The code I have so far is this:
cellview = pya.CellView().active()
view     = cellview.view()
layout   = cellview.layout()
top_cell = layout.top_cell()
myLayer = pya.LayerInfo( 23, 5, 'myLayer')
layout.layer(myLayer)
pya.LayoutView().current().add_missing_layers()
pcell = layout.create_cell("CIRCLE", "Basic", {"layer" : myLayer, "actual_radius" : 100.0, "npoints" : 128 } )
trans = pya.Trans(pya.Trans.R0, 0, 0)
#top_cell.insert(pya.CellInstArray(pcell.cell_index(), trans))
view.max_hier()
Without the last insert command I can drag-n-drop the pcell from the "Cells" view, but I was wondering If there is a way to bring the pcell to the cursor.
Also, I was unable to find a way (or a similar thread), after the 'insert' command, to zoom-fit by code up to the newly created pcell. Is there any way for that?
I think this thread may lead to what I want to do.
Chris
I dont know how to get the position of the mouse, but to select the view region in micron coordinates use layout.zoom_box
Caputring mouse position is discussed here.
Hi jheinsoo,
Thanks for the answer, I think that you are right for the the zoom-fitting! I guess I never saw these methods. I will try to combine selecting the newly created pcell and then zoom-fit with the "zoom_fit_sel" method. I'll give feedback in that. Thank you!
I don't want to capture the position of the cursor, I want to re-produce the pcell hovering effect before placing an instance at the layout with plain code, if that is possible. From a previous discussion with Matthias I understood that several features that are implemented as "plugins" are not accessible via standard methods.
Chris
Hi Chris,
At the risk of repeating myself: I don't know if it is feasible to implement such a feature in Python. The Python API is not equivalent to the internal API. It's provided for certain applications such a scripted layout generation, layout analysis, layout formation, report generation etc. It is not built for reproducing the features of the UI. The Plugin class provides a way to add some UI functionality, but on an intentionally simplistic level.
Specifically and unlike some other tools, the UI is not implementated in Python, but in C++. That's where you need to go to if you're planning to implement really interactive features.
Thank you for your answer, I was hoping that may exist a way to trigger an internal method of this plugin, or anything external, with the pcell information (pcell name, library, parameters dictionary) generated by code, without I have to use the parameters UI to parameterising it, and be able to hover the pcell and place it at will.
Chris
The answer of the OP question is answered by Matthias in this post.
Chris
