I've been trying to compile the current version of KLayout on Debian 10 Buster.
Sadly, I get stuck in a sort of compilation loop, which repeats itself.
I'd be grateful for any help, and have attached the repeating segment below:
At global scope:
cc1plus: warning: unrecognized command line option ‘-Wno-reserved-user-defined-literal’
g++ -c -m64 -pipe -std=c++0x -fvisibility=hidden -O2 -D_REENTRANT -Wall -W -pedantic -Woverloaded-virtual -Wsign-promo -Wsynth -Wno-deprecated -Wno-long-long -Wno-strict-aliasing -Wno-deprecated-declarations -Wno-reserved-user-defined-literal -fPIC -DHAVE_QTBINDINGS -DHAVE_PYTHON -DHAVE_RUBY -DHAVE_RUBY_VERSION_CODE=20505 -DHAVE_QT -DKLAYOUT_VERSION=0.26.3 -DKLAYOUT_VERSION_REV=ab32f260 -DKLAYOUT_VERSION_DATE=2020-02-02 -DKLAYOUT_MAJOR_VERSION=0 -DKLAYOUT_MINOR_VERSION=26 -DKLAYOUT_TINY_VERSION=3 -DQT_NO_DEBUG -DQT_SCRIPT_LIB -DQT_SQL_LIB -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++-64 -I../../../src/db/unit_tests -I/usr/include/qt4/QtDesigner -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtNetwork -I/usr/include/qt4/QtGui -I/usr/include/qt4/QtXml -I/usr/include/qt4/QtSql -I/usr/include/qt4/QtScript -I/usr/include/qt4 -I/usr/include/qt4/QtTest -I../../../src/tl/tl -I../../../src/db/db -I../../../src/gsi/gsi -I. -I../../../src/db/unit_tests -I. -o dbLayout.o ../../../src/db/unit_tests/dbLayout.cc
In file included from ../../../src/tl/tl/tlEvents.h:133,
                 from ../../../src/tl/tl/tlObjectCollection.h:28,
                 from ../../../src/tl/tl/tlLog.h:31,
                 from ../../../src/tl/tl/tlClassRegistry.h:29,
                 from ../../../src/db/db/dbUserObject.h:36,
                 from ../../../src/db/db/dbBoxConvert.h:32,
                 from ../../../src/db/db/dbInstances.h:32,
                 from ../../../src/db/db/dbCell.h:28,
                 from ../../../src/db/db/dbLayout.h:33,
                 from ../../../src/db/unit_tests/dbLayout.cc:25:
../../../src/tl/tl/tlEventsVar.h: In member function ‘virtual void tl::generic_event_function<T, void, void, void, void, void>::call(tl::Object)’:
../../../src/tl/tl/tlEventsVar.h:118:13: warning: unnecessary parentheses in declaration of ‘argv’ [-Wparentheses]
       void *(argv[]) = { _CALLARGPTRS };
../../../src/tl/tl/tlEventsVar.h: In member function ‘virtual void tl::generic_event_function_with_data<T, D, void, void, void, void, void>::call(tl::Object)’:
../../../src/tl/tl/tlEventsVar.h:148:13: warning: unnecessary parentheses in declaration of ‘argv’ [-Wparentheses]
Is the compilation really stuck or are there just a lot of these warnings? Compilation may take about one hour on a single CPU.
Hi Matthias, indeed i just got a lot of those warnings.
Didn't know compilation would take so long. Thank you very much for your help.
Sorry to bother again. Once the compile is finished I end up with the binary files in "bin-release".
I can't execute the "klayout" file from bash, is that correct?
How do I proceed with the binaries? I didn't find any info on github or the build instructions how to get to an executable program, and somehow always assumed the binaries would be executable...
Sorry for the rookie questions.
Not a rookie question in my opinion
 . It is not always that easy to find out how to do it, since there are usually multiple different ways to do it with any projects.
Maybe I can show you how I do it:
First obviously git clone the repository.
Then do the following in the repository folder:
This will first build KLayout, build it ( with how many processors your machine has), and then install it to
/usr/local/klayout(this is the make install part)./usr/localis the folder (at least in debian) where user compiled projects should reside. Then finally I install a symlink into thebinto make it directly accessible in any shell.I know that ideally library files would reside in
/usr/local/lib/klayoutand the binary in/usr/local/bin, but I haven't figured out how to separate them, yet. The ideal approach would be to build a.debpackage, but I am a bit lost how to build one. Maybe Matthias can bring more insight to that, as I think he has a CI way to build itBest,
Sebastian
P.S. @Matthias , is the multiline code formatting different than in the old style? I had to use quote for it, as the preview would look horrible otherwise, at least in the preview.
Hi Sebastian, thanks for the quick reply, and the clear and detailed instructions.
With your suggestions I was able to complete the install. Instead of creating a symbolic link I went for a normal .desktop file.
Thanks again for the great support. I learned a lot in the process!
Very good
Actually "-prefix" is very similar to what you need in autoconf too. As KLayout's build is qmake based I can't make good use of autoconf, hence the build script.
Instead of using prefix you can also copy "bin-released" wherever you want and set "LD_LIBRARY_PATH" to point to it. This is how I run test builds. Recently the Linux people added a nice feature to allow RPATH to be set to a relative one. But I have not tried whether this will solve the binary path relocation problem once and for all.
@Sebastian I'm not aware of changes in the Markdown processing. I have used fenced code blocks (https://github.github.com/gfm/#indented-code-blocks) before and it still works. Maybe indented code blocks don't work any more. Vanilla appears to be using php-markdown (https://github.com/michelf/php-markdown). So please see the documentation there.
