I manage to generate netlist via python API, browse the nets, pins in the net and subcircuits of the pins. Now I would like to access the cell referenced by the subcircuit and the pcell parameters of the cell. How to do that? I have tried cell_index=pin_ref.subcircuit().circuit_ref().cell_index to get the cell index, but these cell indexes do not seem to correspond to the layout.cell(cell_index) DB. Sometimes the cell_index does not even exist in the layout. Also layout.cell(pin_ref.subcircuit().circuit_ref().cell_index).name) gives a completely different result than pin_ref.subcircuit().circuit_ref().name.
Here is a full example of my test code
layout = ...
top_cell = layout.top_cell()
shapes_iter = layout.begin_shapes(top_cell, layout.layer(foo))
ltn = pya.LayoutToNetlist(shapes_iter)
connector_region = ltn.make_layer( layout.layer(foo, "connector")
ltn.connect(connector_region)
ltn.extract_netlist()
netlist = ltn.netlist()
for circuit in netlist.each_circuit():
print(circuit.name)
circuit = netlist.circuit_by_name(bar)
used_cells = set()
for net in circuit.each_net():
print("net:", net.expanded_name())
for pin_refin net.each_subcircuit_pin():
try:
print("- pin:", pin_ref.pin().name(), ":", pin_ref.pin().expanded_name(), "subcircuit:", pin_ref.subcircuit().name, ":", pin_ref.subcircuit().expanded_name(), "subcircuit ref:", pin_ref.subcircuit().circuit_ref().name, "subcircuit cell id", pin_ref.subcircuit().circuit_ref().cell_index, "cell name", layout.cell(pin_ref.subcircuit().circuit_ref().cell_index).name)
except:
print("- pin:", pin_ref.pin().name(), ":", pin_ref.pin().expanded_name(), "subcircuit:", pin_ref.subcircuit().name, ":", pin_ref.subcircuit().expanded_name(), "subcircuit ref:", pin_ref.subcircuit().circuit_ref().name, "subcircuit cell id", pin_ref.subcircuit().circuit_ref().cell_index, "not present in the layout")
used_cells.add(pin_ref.subcircuit().circuit_ref().cell_index)
print()
print(used_cells)
Now I figured out that the cell indexes actually refer to the
internal_layoutand I can get the correct cell name fromltn.internal_layout().cell(pin_ref.subcircuit().circuit_ref().cell_index).name.However, these are static copies of PCells. Is there any way to retrieve a reference to the original PCell such that I could obtain vales of the PCell parameters?
I think I figured it out
name=pin_ref.subcircuit().circuit_ref().namegives a name which also exists in the layout and the PCell can be retrieved by
cell = layout.cell(name).Yes, that's one option.
You can also use
to get a CellMapping object. With this you can get the corresponding original cell index this way:
There is a reason why there is an internal layout: in the presence of clipping or hierarchy path enabling/disabling the internal layout will deviate in structure from the original one and cell variants may be present there. In this case, there is no non-ambiguous mapping back to the original layout. These cases will trigger the "else" path above.
Thanks! I made use of the
cell_mapping.Just for record for future readers, in your example the
internal_cellandoriginal_cellare notCellobjects but cell indices.
