Hi, Matthias!
Current Shape API allows to query one property at time. It'll be great to have method to return number of properties and all properties as dict to simplify code that handle them: to skip shapes without properties and reduce number of Python-C++ transfers.
This is what "prop_id" is for. It can be used to retrieve the full property set via the layout:
Hi, Matthias!
Thank you for explanations!
