Back to bother you again.
I’ve been assigned a task to make a GDS file of a Mandelbrot Fractal. I’ve found a short VB Excel macro code below.
Sub frac1()
For y = 1 To 200
    For x = 1 To 200
        i = 0
        zx = 0
        zy = 0
        cx = -2 + x / 50
        cy = -2 + y / 50
        Do Until (i = 255) Or (zx * zx + zy * zy) >= 4
            xt = zx * zy
            zx = zx * zx - zy * zy + cx
            zy = 2 * xt + cy
            i = i + 1
        Loop
        Cells(y, x).Interior.Color = VBA.RGB(10, 10, i * 10)
 ‘    my additional line to output X and Y and i values in each cell      Cells(y, x).Value = x & "," & y & ",L" & i
    Next x
Next y
End Sub
To make a GDS of this I did it the long way in Excel where I got the X and Y co-ordinates and i as the layer then (in excel) defined each layer separately and copied and pasted about 40000 individual “cell.shapes” commands for each individual pixel (1um box).
# create a new view (mode 1) with an empty layout
main_window = RBA::Application::instance.main_window
layout = main_window.create_layout(1).layout
layout_view = main_window.current_view
# set the database unit (shown as an example, the default is 0.001)
layout.dbu = 0.001
# create a cell
cell = layout.create_cell("TOP")
# create a layer
Layer1= layout.insert_layer(RBA::LayerInfo::new(1, 0))
Layer2= layout.insert_layer(RBA::LayerInfo::new(2, 0))
Etc  …
cell.shapes(Layer1).insert(RBA::Box::new(29,28,30,29))
cell.shapes(Layer1).insert(RBA::Box::new(30,28,31,29))
cell.shapes(Layer2).insert(RBA::Box::new(31,28,32,29))
cell.shapes(Layer2).insert(RBA::Box::new(32,28,33,29))
etc…  40000 times
# select the top cell in the view, set up the view's layer list and
# fit the viewport to the extensions of our layout
layout_view.select_cell(cell.cell_index, 0)
layout_view.add_missing_layers
layout_view.zoom_fit
It worked but was quite a long process. (see attached image)
I tried using “while” function for the loop but I don’t know how to include the OR statement. I also have trouble defining the layer names i.e. Combining text “Layer” with variable (1) to make Layer1 etc.
Is there any possibility that you could convert the VB routine to Ruby?
Stretching my luck here: Is it also possible to write a Ruby routine that would enable me to merge each layer automatically so that I don’t have to manually view each one individually, select all then merge. i.e. loop that show each layer individually, select all, merge, unselect then move onto next layer.
Many thanks,
Richard
Come on, you're pulling my leg, are you?
I bet you guys were sitting together with a beer and tried to come up with the strangest request ever posted to this forum. I'd bet no one ever printed a Mandelbrot set on silicon!
But it's fun, so I give you this:
Cheers!
Awesome!!!
We're going to try it out on our new e-beam if I can up the resolution and subtract the central (black) region (in the excel code it works if I plot only where i = 255).
Again, I'm in awe of your talent
Very much appreciated
Richard
This is the most beautiful code I ever seen for ebeam
Thank you Matthias for sharing the code, I learned a lot from it.
Elias
Just following up on this, managed to put the design on a photo mask with a 2um pixel. Looks good. Looking forward to the higher definition e-beam write soon.
Cheers
Richard
@ram1 Thanks for sharing this nice image!
