from __future__ import annotations
# some of these types are deprecated: https://www.python.org/dev/peps/pep-0585/
from typing import Protocol, Dict, List, Iterator, Tuple, TypeVar, Optional
T = TypeVar('T')
Okay.
What is available strongly depends in the Python version your KLayout instance comes with. If you want to have a specific version with specific capabilities, you'll need to build KLayout against it.
Another option is to use the klayout module from PyPI with your favorite Python. If you're happy with the database part it will be sufficient.
Thanks for the reply I am currently using Anaconda with python 3.8
So how exactly do I use the PyPI module with klayout ?
Regards
Tracy
Please try "pip install klayout".
You can use "import klayout.db as pya" to get the "pya" namespace. But it will just provide you with the layout manipulation API.
Thanks this works for windows do I need too set a path or env variable?
Tracy
Matthias,
I have gotten this far and would like to load the following modules,
many thanks for your help
Regards
Tracy
Matthias,
I have solved the Protocol module issue based on the
following https://pypi.org/project/typing-extensions/
1) download https://pypi.org/project/typing-extensions/#files
https://files.pythonhosted.org/packages/16/06/0f7367eafb692f73158e5c5cbca1aec798cdf78be5167f6415dd4205fa32/typing_extensions-3.7.4.3.tar.gz .
2) Extract the tar file then change to the directory typing_extensions-3.7.4.3
find either the src_py2 or src_py3 , depending on python version used in Klayout,
cd to either src dir
3) then copy typing_extensions, to C:\Users....\AppData\Roaming\KLayout\lib\python3.7
I have tested and this works this could be added to Salt but I do not know how
this opens up all kinds of possibilities .
Again thanks for providing this great tool
Regards
Tracy
Code as follows based on Klayout 0.26.9
Hi Tracy,
thanks for sharing this code and the recipe for installing the extension.
Anytime to help the user community ,
We all learn as we go with this great tool.
Now if I could get EasyGui to work in the same way
Very good
BTW: in the recent 0.26.10 version, I have included "typing" in the Windows installation.
