Hello Matthias,
I'm trying to split rectilinear polygons in rectangles in the DRC environment. Not sure if the code below is the way to go: it produces some shifts for some of the structures and I can't figure out why... Any idea what the issue might be?
Very amazed by the power of KLayout!!!
Layer01 = input(1,0)
Layer01A = Layer01.rectilinear
Layer01B = polygon_layer
Layer01A.each {|polygon|
trapezoids = polygon.to_itype.decompose_trapezoids
trapezoids.each{|trapezoid|
Layer01B.insert(trapezoid.to_dtype)
Layer01A.output(10,0)
Layer01B.output(11,0)
I managed to fix it, "to_itype(1.dbu)" instead of "to_itype", and "to_dtype(1.dbu)" instead of "to_dtype"...
Very good ...
Well, once again I'm pleading for using code formatting ...
As the DRC feature is based on the RBA::Region class and the latter offers a universal "decompose_trapezoids" method, it's possible to employ the latter.
A DRC is based on a dynamic language you can extend the DRCLayer class at runtime to expose this feature. This code tricks DRC into having a new method called "decompose_trapezoids":
Thanks for the suggestion, it works like a charm!!! I still got a lot to learn... :-O
I'm now looking into these mode parameters TD_htrapezoids, TD_simple, TD_vtrapezoids:
1) decompose_trapezoids_to_region(TD_htrapezoids) -> Error: Uninitialized Constant
2) decompose_trapezoids_to_region(0) -> Works fine
Do these constants need to be initialized somehow?
0 -> represents TD_htrapezoids
1 -> represents TD_simple???
2 -> represents TD_vtrapezoids???
@Thomas The values are "RBA::Polygon::TD_htrapezoids" etc. Don't use the integer equivalents as they might change in future releases.
Great! Scripts updated. Thank you Matthias!
