Hi all, I am a postgraduate student, I am trying to write some rules, and I have some questions.
First, I wanna check the width, but I also wanna ensure the width is not affected by some polygons with the wrong angle, What should I do?
This is what I done , What should I add to achieve a more complete width check?
min_aa_w = 500.nm
r_aa_w = aa.width(min_aa_w )
r_aa_w.output("AA_W: AAwidth < 0.5 µm")
I used calibre for DRC inspection before. I also want to know what is the biggest difference between Klayout and Calibre for DRC?
Second,How to write a DRC script when checking the distance between different nets?
The specific requirement is Space between DNW and NW at different nets
I just write like this, but I do not know how to write  "different net"
min_DNW__NW_s = 300.nm
r__DNW__NW_s = dnw.separation(nw, min_DNW__NW_s )
r__DNW__NW_s.output("DNW__NW_s: space to nw distance < #{'%.12g' % min_DNW__NW_s } µm")
Thanks in advance!
Best wishes!
Shida
Ok , i know how to write the rules to check the angle now, but I still confused on different nets problem..
@Shida I'm sorry, but KLayout currently can't check distances between different nets. Thats a development branch which is not yet addressed.
Please don't expect you can easily substitute Calibre by KLayout. Mentor doesn't take the money for no reason.
@Matthias
Thank for you reply!
Ok, That makes sense..
Where can I know the difference between Klayout and Calibre? I am very curious.
Maybe the GDS design I made is not so complicated. I compared the two software myself, and I began to think that there was no difference between Klayout and Calibre.
I really respect you very much. I think klayout really helps a lot of people who can't afford calibre to learn!
Best wishes!
Shida
By the way,
I am trying to check some polygons with 45-degree edge.
min_edge_aa_fourfive = 0.45um
edge_aa_fourfive = aa.with_angle(45.degree)
r_aa_width_fourfive = edge_aa_fourfive.width(min_edge_aa_fourfive )
r_aa_width_fourfive .output("AA_W with 45 degree : AAwidth 45 degree < 0.45 µm")
But it does not work
Thanks in advance!
You can find many DRC examples here :
https://github.com/laurentc2/SKY130_for_KLayout/blob/main/drc/drc_sky130.lydrc
https://github.com/laurentc2/FreePDK45_for_KLayout/blob/master/drc/drc_freepdk45.lydrc
For your 45 degree DRC :
or more simple :
Thanks @laurent_c
Thanks, @laurent_c , I still confused...
In your code, it selects the 45 degrees, but what I wanna do is to check the width of 45 degrees of aa
how can I do that?
Sorry, here is the way to check it :
Thanks! @laurent_c
You are so nice! It helps me a lot.
I have already read all the code you upload in github, it is very Conciseness but useful, and I learn a lot!
Wish you have a good day.
BEST WISHES
Shida
Hi @Matthias,
Out of interest on one thing you said:
...which branch are you referring to, and do you currently have a specific release version in mind which should have this feature?
I noticed for the upcoming 0.27 release, you noted the following in the Changelog
So I'm not expecting it in 0.27, or is this a different feature?
Thanks again for this great tool!
Christian
Just a thought
You could use the netracer to save the needed nets to another GDS file
then run your DRC against the traced nets
@tagger5896 : I imagine this to be feasible for layouts with a small number of nets. Say we have 3 nets, A, B and C. For the checks Shida referred to in the initial post - namely, checking the distance between different nets on layer NW, for example - I think this would mean implementing the following steps:
Is there a better way?
@cgelinek_radlogic
There is always a way , some how, just have to think it through .
Your concept is there .
As Matthias has pointed out and it's true Klayout DRC is not Caliber
Unfortunately there is not as I am aware an append option to the layout.write function.
If so you could parse through the nets, with the nettrace then save as GDS file then run
run the DRC .
I have been down this rabbit hole in the past .
I have code that extracts a net/path based on text label and saves to the GDS file.
And am currently wrapping my head around how to solve this, another rabbit hole.
@dick_freebird
yes that's another way .
Dear all,
maybe a need to shed some light on that:
The "connected" feature basically is quite simple if you can tag polygons with their net ID. You only need to check distances between polygons with a different net ID to implement CONNECTED.
However, it's not trivial in the hierarchical case. There is not a single net ID. Instead, what may be different nets locally in a cell may be a single net when these nets are connected outside the cell. Furthermore, the same cell may be different nets in one instance and connected nets in another. Hence the cell instances need to be treated differently.
The whole topic is related to merging. KLayout first merges all polygons before it does a space (or other) check. That's how isolated, notch and space checks are differentiated: "isolated" operates on separated (post-merge) polygons, "notch" operates on a single polygon and "space" on both. This already is close to "connected" (notch) or "not connected" (isolated), but without the connectivity across multiple layers.
In that sense, net formation is just an extension of the merging step. Or: the merging step is a special case of connecting nets. As merging is a weak spot in the DRC implementation, my plan is to improve merge implementation following this scheme while introducing CONNECTED. But this is a major redesign of the DRC internals and it's not going to happen quickly.
