I was trying to use the gross_die.rbm script with klayout 0.26.11. I saved the script in the installation folder. But I am getting the following script error as soon as I am starting KLayout. My OS is Windows10.
uninitialized constant MenuAction
  C:/Users/supra/AppData/Roaming/KLayout/gross_die.rbm:23:in `main'
What am I doing wrong here? Please help.
I see that same error.
Can you try to add:
before line:
$gross_die = MenuAction.new( "Gross die / Yield", "" ) doIt runs fine for me, but I noticed the "MenuAction" class was defined in another .rbm file I have present in my installation folder, so probably it is nowhere defined if you only have gross_die.rbm in the installation folder...
@tomas2004 Thanks for pointing this out.
However, you do not necessarily need MenuAction today. An Action can be directly bound to code using "on_triggered":
@tomas2004
It worked. Thanks a lot.
It saved a lot of work. Thanks again.
Supratim
@ Matthias
You always have a helpful hint, if only people ask.
But that is a "lagging function".
So let me ask this - when is your "Klayout Verification
Scripting for Dummies" book coming out?
That being a different thing than the manual, good
as it may be.
Good idea. Yes, I should write that book!
I got a title page already (https://imgflip.com/memegenerator/59165342/For-Dummies):
I have this problem too. With the addition of the snippet from your May 10 post, I get a new error:
Ambiguous overload variants - multiple method declaration match arguments in Trans::initialize in Action::triggered
../gross_die.rb:455:in 'initialize'
../gross_die.rb:455:in 'new'
../gross_die.rb:455:in 'block in '
../gross_die.rb:31:in 'triggered'
I'm sorry, I don't maintain this script. And I cannot guess which is the patch you applied and how you did that.
If it is useful, please create a project somewhere (GitHub if you like) and put the script there. This is a basis for debugging and further development.
