I am doing DRC and I am running into a problem when I want to check the angle between two polygons. There are also a load of copies of this design throughout.
You can see the angle that I want to check in the image below in red. These are all in the same layer.
Tristian
Hi Tristan,
maybe that is possible somehow, but it's a little beyond the abilities of a DRC tool.
Here is a proposal. It's based on the assumption that it's possible to identify the opening with a space check of 300nm space. It needs version 0.27.3 because this has "without_internal_angle":
This works a treat, thanks a lot!
Tristian
