I'm writing a script to manipulate GDS, and found that it fails to open GDS on Mac, while ok on Windows.
The script to read GDS is:
    # Read and create a layout
    lo = LoadLayoutOptions::new
    lo.layer_map.assign(lm)
    ly = Layout::new
    crt_ly = CellView::active
    file_name = crt_ly.name
    ly.read(crt_ly.name, lo)
Error message on Mac is:
"Unable to open file: filename.gds (errno=2) in Layout::read"
 It is confirmed that "file_name" is actually the file name (without path) of active GDS.
Any idea to solve this problem? Thanks.
@akita11 The paths are resolved relative to the current directory and this is the one you start KLayout from. I assume that MacOS uses a different place than Windows.
You should take the file path from "crt_ly.filename" which gives you the full path.
Thanks, actually, it works by using the attribute of "filename" instead of "name", like:
y.read(crt_ly.filename, lo)
