I use the following script to do tiling, but I find it needs long time to run.
Is there a way to optimize?
Beside, I want to get the chip size by extent automaticly, as the folling:
chip =extent.sized(-20.um,-200.um),
but it shows there are something wrong.
deep
tiles(1000)
threads(24)
micron2dbu = RBA::CplxTrans::new(ly.dbu).inverted
top_cell = ly.top_cell
HMWG = ly.layer(10, 0)
SLABWG = ly.layer(11, 0)
STRIPWG= ly.layer(12, 0)
M1 = ly.layer(105, 0)
chip =RBA::DBox::new(-9800.00000,-7900.00000,9800.00000,7900.00000)
distance = 20.0  # micron
ncpus = 4
tile_size = 15600.0
fc_origin1 = RBA::DPoint::new(0.0, 0.0)
fc_origin2 = RBA::DPoint::new(2.5, 2.5)
fc_name1 = "dummy_WG"
fc_name2 = "dummy_M1"
fc_box = RBA::DBox::new(-3.25.um,-3.25.um, 3.25.um,3.25.um)
fill_layer1 = ly.layer(1, 0)
fill_layer2 = ly.layer(40, 0)
fill_shape = RBA::DBox::new(-2.5.um,-2.5.um, 2.5.um,2.5.um)
fill_cell1 = ly.cell(fc_name1)
if ! fill_cell1
  fill_cell1 = ly.create_cell(fc_name1)
  fill_shape_in_dbu = micron2dbu * fill_shape
  fill_cell1.shapes(fill_layer1).insert(fill_shape_in_dbu)
fill_cell2 = ly.cell(fc_name2)
if ! fill_cell2
  fill_cell2 = ly.create_cell(fc_name2)
  fill_cell2.shapes(fill_layer2).insert(fill_shape_in_dbu)
fc_box_in_dbu = micron2dbu * fc_box
fc_origin_in_dbu1 = fc_origin1 && (micron2dbu * fc_origin1)
fc_origin_in_dbu2 = fc_origin2 && (micron2dbu * fc_origin2)
class TilingOperator < RBA::TileOutputReceiver
  def initialize(ly, top_cell, *fill_args)
    @ly = ly
    @top_cell = top_cell
    @fill_args = fill_args
  def put(ix, iy, tile, obj, dbu, clip)
@top_cell.fill_region(obj, *@fill_args)
tp.frame= chip
tp.dbu = ly.dbu
tp.threads = ncpus
tp.input("HMWG", ly, top_cell.cell_index, HMWG)
tp.input("SLABWG", ly, top_cell.cell_index, SLABWG)
tp.input("STRIPWG", ly, top_cell.cell_index, STRIPWG)
tp.input("M1", ly, top_cell.cell_index, M1)
tp.var("dist", distance / ly.dbu)
tp.output("to_fillWG", TilingOperator::new(ly, top_cell, fill_cell1.cell_index, fc_box_in_dbu, fc_origin_in_dbu1))
tp.queue("var exclude = HMWG +SLABWG + STRIPWG ; var fill_region = _tile & _frame - exclude.sized(dist); _output(to_fillWG, fill_region)")
tp.output("to_fillM1", TilingOperator::new(ly, top_cell, fill_cell2.cell_index, fc_box_in_dbu, fc_origin_in_dbu2))
tp.queue("var exclude = M1; var fill_region = _tile & _frame - exclude.sized(dist); _output(to_fillM1, fill_region)")
begin
  ly.start_changes   # makes the layout handle many changes more efficiently
  tp.execute("Tiled fill")
ensure
  ly.end_changes
Could you please use code formatting ... triple backticks on a single line before and after the code ... this is painful to read.
Beside that: you're using DRC commands at the beginning, but the rest is a Ruby script. What are you trying to do?
For the extent, you should use:
I can't give advice about optimization without a test case. Try to figure out what is the main performance detractor (disable TilingOperator#put, check how much faster it gets, disable other parts like the booleans inside the tiling processor script etc.). You can try increasing the number of CPUs or play with the tile size - maybe 1000 micron is so big that memory swapping happens.
@Matthias,
Thank you very much for your respond.
I am sorry, but how to make it shows in code formatting, I tried to use """ or ‘’‘ on a single line before and after the code,but it still shows as before.
Beside, when I replace
chip =RBA::DBox::new(-9800.00000,-7900.00000,9800.00000,7900.00000),
with
chip = top_cell.bbox.enlarged(0, 0)
,it seems that titling pattern is not right, it is a box of 5x5um,it is strange.
What could be this caused by?
Thank you for your suggestion. I will try to debug which part consumes most of the time.
I single line with backticks with code looks this way:
And without your layout I cannot debug the problem either.
BTW: why using "enlarged(0, 0)"?
@Matthias ,
Thank you for your respond.
This character does work.
About "enlarged(0, 0)", I just follow the script you put and maybe this is useful when I need to size, so I keep it.
Thank you for your willness to debug the problem. This is difficult to regroup a new layout.
When I have such a large layout that can be shared, I will seek for your help again.
Weiling
