Hello
Recently PCell with param TypeList entries have been returning nil for selections. To test this I created a new PCell. The only thing I changed (except for the default cell and lib names) was the addition of the following to the initialize section:
      #param(:item, TypeList,"Choose item", :choices=>[["choice1",0],["choice2",1],["choice3",2],["choice4",3]])
      @items = [["choice1",0],["choice2",1],["choice3",2],["choice4",3]]
      param(:item, TypeList,"Choose item", :choices=>@items)
The library installs but the are no PCell parameter entries at all. My previously coded PCells do have list items but, as I said the choices  seem to return nil.
I tried to reproduce, but with little success. I changed the code of one PCell of mine to use a member variable for the item list instead of the item list directly. Still, the parameters are there and also the choices.
Basically, it should not make a difference whether you give the items directly or from a member variable. I assume the problem is related to something else.
Could you paste some full code that reproduces the problem?
Hi Mathias,
This was my fault. I did not change all the instances of the module name which cause the issue.
Rick
Very good
 Thanks for letting me know.
