Hellow @Matthias !
I faced with the following issue.
I tunned options for DEF import in "Technology Manager->Reader options->LEF/DEF->Production".
I enabled "Routing" and "Special routing" and defined "Layer name Suffix" and "GDS data type"  for each of them.
And after I exported Technology data to XML file (see attached Tech_export.txt).
In this file I see that the field names are equal for routing and special routing and second overwrites first one.
In result, after such XML importing I see in technology manager, that fields for Routing are filled with data from Special routing and fields for Special routing are empty.
Is this a bug and how can I fix it? I tried to rename to e.t.c without any success.
I recall there was a bug in the configuration scheme of LEF/DEF once. What is the KLayout version you're using?
@Matthias,
I have updated up to the latest version 0.27.11 and see that the issue has already fixed.
Sorry
No worries. Thanks for the feedback
