I am able to read a DEF+LEF successfully in klayout. To display the net name, I can select the net, press Q, then press the button "User Property". I don't want to see all the net names displayed. Just the name of the one that is selected, eventually with a press of a key
I've tried to assign the letter W to the function "cell_user_properties" using the setup dialog (in Customize menu) , but nothing happens.
What is the best/quickest way to display the net name in a window after a keypress (or in the bottom of the main window) for a selected net ?
Thank you
Ronan
Hi Ronan,
there is no such feature yet as user properties are rarely used in the GDS2 world that KLayout stems from. After all, KLayout is not a LEF/DEF viewer, but a mask layout tool.
It is possible to install a callback through a script that tracks the selection and displays a specific user property as the net name in the status bar (this will hide the selection information). Here is some sketch:
Please note the TODO comment.
Thank you. I'll try that asap
Could you elaborate on the use-case ?
On top of layout viewing, openroad -gui also has netlist and timing browsers ...
Plus they are in touch with me to optimize their viewer
Use case: quickly debug DRC errors related to Non Default Rule (NDR) routing - Using a DEF can be much more effcient to identify the net(s) causing the issues
