the return type of pya.MainWindow.instance() is sometimes wrong.
edited October 2018 in Python scripting
I am now developing a python plugin upon klayout, but for the following code:
main_window = pya.MainWindow.instance()
print(main_window.__class__)
sometimes it will print class 'pya.PluginRoot'.
and if I stop the program and run it again, sometimes it will get the correct result. e.g. class 'pya.MainWindow'.
I don't know why. I get the code from master branch in git about one month ago.
And I also download the klayout-0.25.5 from this website and build it. But the result is same.
  • Hi William,
    PluginRoot is an interface implemented by MainWindow, but it's not exposed as a base class of MainWindow. So that may explain this duality. MainWindow is a superset of plugin root, so that should not hurt. But maybe it's possible to reduce the Python MainWindow object to PluginRoot under some circumstances. The only way I can think of are related the "root" argument in PluginFactory#create_plugin - for example if you store this value in some variable, the MainWindow object may incorrectly be identified with this PluginRoot object. That's the magic of C++/Python bridging.
  • Hi William,
    I am considering this an actual bug. There is a ticket for this: https://github.com/klayoutmatthias/klayout/issues/191.
  • Hi, Matthias
    Thanks for your comment.
    William.
  • Hi William,
    I have published a simple workaround for this issue in the GitHub ticket. Maybe this helps.
