I would like to bind a QPushButton to a function,
If I run the simple script bellow, I get a "Button clicked" printed when starting the program and no action when clicking on the pushbutton,
what is it that I am missing?
def test():
print("Button clicked")
return
dialog = pya.QDialog.new(pya.Application.instance().main_window())
pya.QPushButton("ok....",dialog).clicked = test()
dialog.show()
Thanks, ![]()
Hi jonathan,
that's simple. It's:
(not the missing brackets after "test").
You want to bind the function itself, not the result of the function call (which is "None" and essentially resets the binding).
Thanks a lot again Matthias. all make more sense now.
Overall, this would also means that, on the case I want to run a function with arguments, I should either create a new PushButton class with input argument or set the arguments as global variable.
Hi jonathan,
what arguments would you like to see? clicked doesn't have arguments, so binding a function with arguments to it does not make sense.
If you have a signal with a value, simply bind to a function which expects a value:
You can bind to a function with less arguments too:
If you want to add an argument, you can use lambdas for example:
Hi, I have only now learned about lambda, thank you so much for the help and the very useful and complete example scripts!
