I installed the  recent version of klayout.
I am trying to run a script from Klayout GUI
When I try to import numpy module it says: No module named numpy.
I didn't have that problem in the previous version.
Any ideas on how to fix it?
These are the two modules that are causing problem.
import numpy
import configparser
Is this the Windows version? 32bit? 64bit?
It is linux
So next question: standard package (-> KLayout will use the system Python) or did you build it yourself (-> KLayout will use the packages from the Python installation you built against).
Hello Matthias,
sorry for the late answer. I am not sure about the answer to this question because I didn't install the python (it is a shared computer).
However, I solved the problem by adding the location of the module folder into system path by using:
import sys
sys.path.append(full_path_of_the_directory_where_module_is_located)
