Hi, Matthias
I have built the klayout code from github. It works great.
From the code tree, I guess pya and pymod should be the API wrapper for python. However, they all work embedded in kaylayout framework. In PyPi, there is independent klayout packge for python, built by you and Thomaslima. Can you tell me how to do the same python package build as you did?
Thank you very much.
Mountqi
actually PyPI package is build by a Travis job
You'll find the details in ".travis.yml" in the sources.
The build is based on "setup.py" (setuptools). Provided you have the necessary Linux packages (gcc, libcurl-devel, python-devel ...), all you need to do is to say
thank you, Matthias.
setup.py works fine.
