It looks like LayoutView.on_selection_changed callback is not called when selection changed from some objects to none of them. I'd like to perform some action (like window hiding) is such scenario.
Hi Eugene,
thanks for reporting this. I'll verify that and create a ticket if necessary. I recall I have seen this issue myself, but I'm not sure. Maybe it's already fixed in master.
Hi, Matthias!
I tried 0.26.9 and I was not correct in original problem description.
LayoutView.on_selection_changedis called when object(s) is/are unselected, butLayoutView.has_object_selectionis stillTrueTest code:
import pya main_window = pya.Application.instance().main_window() current_view = main_window.current_view() def on_selection_changed(main_window, current_view): count = 0 for selected_object in current_view.each_object_selected(): count += 1 if current_view.has_object_selection: main_window.message('Select {0}'.format(count), 2000) else: main_window.message('Unselect', 2000) current_view.on_selection_changed = \ lambda __main_window=main_window, __current_view=current_view: \ on_selection_changed(__main_window, __current_view)@EugeneZelenko thanks a lot for the code!
The problem still persists on master. As a workaround I'd suggest to check for "view.each_object_selected().size == 0". But of course "has_object_selection" should work.
I have created a ticket for this: https://github.com/KLayout/klayout/issues/703
I hope it's easy to fix.
Hi, Matthias!
Thank you for help!
As workaround I use early return from
current_view.each_object_selected()loop inon_selection_changedhandler when object is selected, and code handling no objects selected situation is located after loop.Eugene.
