@Matthias @dick_freebird @MoBe
Proof of Concept Router for Klayout
git hub is here https://github.com/hgroller/KlayoutRouter.git
All text locations must be on an int grid location
no float's at the present time
Layout is based on Matthias si4all dummy pdk
Code consists of :
place both files below in C:/Users/your_path/KLayout/pymacros
Router.py ----- in sys.path.append("C:/Users/your_path/KLayout/pymacros") and change your_path
AstarRouter.py
testroute.gds is the test gds file with Text placements
Load Router.py in the IDE with the testroute.gds file open, the run .
In AstarRouter.py you can play with blockages by adding 1's in the maze array
Have fun, Comments welcomed.
Tracy
Router.py has been updated to do Vert/Horz Metals and Drop vias
Added ToolBar menu...
Working on little bugs
Rules are next ....
Cool! Thanks a lot!
Would you mind formatting the text in Markdown? I guess there are some "#" characters which make the text super large (those are taken as H1 markers).
Matthias,
I tried , let me know how the test's goes on your side
I am in the process of getting this to work with floats, off grid etc.
Tract
Matthias,
Code has been updated to route on any grid that Text is placed on
updated Router.py code
I setup this package, and got some problem. I can execute "Create Array Label pins", but when I execute "Load Router", it showed "DPoint" is not find. I don't know how to fix it? Or anything went wrong ? Furthermore, how to install pdk si4all? Thank you.
I'm sorry, but this is a third-party project. Please try to reach out for the author on GitHub and get support there.
I haven't seen much from Tracy since he got a "straight
job" quite a while back. I think he may pop in sparsely.
Sending him a message here might percolate at least
a notification to his "home" email.
My involvement with this is nil, other than "birds of a
feather" interest.
Thank you @dick_freebird @Matthias .
