I tried the following script, but the region is not taken in account : what did I miss ?
mw = app.main_window
lv = mw.current_view
if lv == nil
  raise "No view selected"
cv = lv.active_cellview
if !cv.is_valid?
  raise "No cell or no layout found"
begin
  # implement undo
  lv.transaction("Undo Boolean")
  ly = cv.layout
  li1 = ly.layer(1, 0)
  li2 = ly.layer(2, 0)
  li3 = ly.layer(3, 0)
  lout = ly.layer(5, 0)
 ly.each_cell do |cell|
  r1 = RBA::Region(cell.begin_shapes_rec(li1))
  r2 = RBA::Region(cell.begin_shapes_rec(li2))
  r3 = RBA::Region(cell.begin_shapes_rec(li3))
  selection = r1 & r2 - r3
  layout.clear_layer(li1)
  layout.clear_layer(li2)
  layout.clear_layer(li3)
  cell.shapes(lout).insert(selection)
ensure
  # implements undo: done.
  lv.update_content
  lv.commit
Hi Laurent,
with "begin_shapes_rec", the shapes plus the ones from the subcells are pulled
Also "layout.clear_layer(li)" will clear the shapes from all cells, not just the ones from the cell you're working on. So eventually the result will depend on the order the cells are called (which is undefined in "each_cell".
I assume you're looking for a pure "cell-local" boolean. In this case you'll need to use per-cell shapes for Region input and need to clear shapes on cell level:
