Dear Manager,
I have an issue while installing the packages provided by Lukas at UBC. However, there's a problem while I try to install the packages.
The problem is that for some packages using the salt server by SiEPIC, my username and password combination cannot pass the authorization.
As seen
I am very sure the user credentials I input is correct since I logged into github worked.
I reached out to Lukas and he suggested that it might be the error of the github verifications. As he put it
May I get some help on this issue? Thank you!
I guess what Lukas mentioned about two-factor verification means I should not turn on the verification of github, which I actually turned it off.
And, strangely, one of my desktop could still access the packages, while two other laptops cannot.
