Hello @Matthias,
I'm trying to develop an LVS deck for sky130nm technology, when I try to extract a resistor Klayout complains that there's no value for R, which is not actually in the spice from the pdk.
an example for a subckt that has resistors:
.subckt sky130_fd_sc_hd__conb_1 VGND VNB VPB VPWR HI LO
 R0 VGND LO sky130_fd_pr__res_generic_po w=480000u l=45000u
 R1 HI VPWR sky130_fd_pr__res_generic_po w=480000u l=45000u
.ends
From my understanding, and correct me if I'm wrong, the R value should be calculated internally from the W, L and rho_sheet.
My work around: Added a temp value for R in the spice (to satisfy the netlist reader) and disable the comparison for that parameter, and use the W and L for comparison. But this work around needs manual modifications in the spice, which is not optimal (putting in mind that I get this spice from the pdk). My implementation for LVS can be found here.
Thank you.
Best,
Marwan
Hi Marwan,
KLayout does not read the resistor model nor does it calculate the values, I'm sorry. It's not a simulator.
