When I run python macro with a debug point it opens with the variables but there is no console showing in the window. I can't find any control that would hide or reveal it. Any tips? I'm trying a complete Uninstaller reinstall now.
Resolved with Uninstall using revo Uninstaller pro. I'd tried several with Uninstaller reinstall cycles using windows alone. I had a few older versions bumping around earlier.
I guess you have just minimized the height of the console panel. There should be a handle at the bottom of the macro IDE window to increase the height of the console.
If you want to get rid of persisted window settings, you can simply remove or rename the File called "klayoutrc" in KLayout's home folder - this is either in
c:\users\yourself\KLayouton Windows or/home/yourself/.klayouton Linux.Matthias
Totally Possible, I see now it has kind of a snapping action down there. Thanks!
