No idea if this solves your issue, but perhaps it helps. If you are missing a particular python package in KLayout it is possible to install it manually, provided you have some python installation with pip. You can run
which should be the current internal python installation of klayout. You may have to chagne the path depending on your installation (in particular python3.8 may be different for different KLayout versions)
pip. You can runwhich should be the current internal python installation of klayout. You may have to chagne the path depending on your installation (in particular
python3.8may be different for different KLayout versions)I'm not sure I understand what the correct line would be
and this emty technologies error accure to me when i try to install everything
I've seen the same error message (m_technologies.empty() ...) with my own installation, but I could not debug the cause yet.
However, in my case it does not seem to cause any trouble. You're sure the package is not installed?
