Hello.
I have a big issue, I can not generate the layout like this video on Klayout
 In this video there is a library called ”Skywaters 130nm Pcells”, but I don’t have it and I don’t know how to create it.
My goal is to generate the layout of a custom transistor where I can choose the L and the W. I did the schematic and to fabricate this chip I need to design its layout.
Thank you for your help.  ![]()
I have these errors when I lunch Klayout
I would go to the source and pull all the setup info you
can find. There should be orderly docs for that as it
purports to be a fully capable PDK. But expect "some
assembly required", for which there ought to be
instructions (or maybe there's a 'board dedicated, where
specific questions get answerd by people who actually
should know).
Of course I have heard that the PDK quality / completeness
leaves some to be desired, but seems to me you're well
short of finding out about that - more like "can't feel my
legs!".
Design management and knowing you've got everything
you need, seems to be a common weak spot in OS CAD
tools. Like, my klayout, xschem and ngspice aspects all
reside in different places, no unified framework or even
a general agreement on how a chip design project ought
to be structured (as even "which tools?" is a variable).
I have been looking for one month practically in full time for a document explaining how to do that. I good in analog and digital design layout and physique of semiconductor, but in I'm worthless in computer science, Instaling Klayout with its librarie require knowledge in computer science. Maybe I missed obvious things during my installation.
Normally is it possible to generate the layout of a transistor with a custom L and W if not Klayout is useless.
klayout does have the PCells and I believe your problem
lies with the scripts which turn properties into polygons -
evidently either absent, or someplace that klayout has not
been told to look.
Scripts have "paths-to". I'd first pore over those docs and
error messages regarding "huh?" to find any filenames,
then search those out to find the real path, then back to
the docs to see where that definition should be declared
(klayoutrc?) and connect the dots.
yesterday i found this : https://gdsfactory.github.io/skywater130/index.html
It is exactly that I need, the problem know is how to integrate it into Klayout ?
I looked for something about it during one month, and I found it by hazard in looking for other thing
I think I have a problem with "gf-config.json", it doesn't exist
That is a peculiar looking Java file and I wonder if it's a
"legacy" from a GloFo kit.
Might go to the root of the PDK and search for *.json,
see what -does- turn up where, maybe there's really a
sky130.json that's just waiting for an invitation from an
install script that needs editing. Or something.
You probably want to get to know your open PDK support
system, whatever it may be. Start with the Skywater inside
folks and the open PDK developers you may find on a
single-topic 'board?
Here's one place to get the lowdown on the hoedown:
The SkyWater Open Source PDK documentation can be found at https://skywater-pdk.rtfd.io.
@CMeyer You're in the wrong place here. This is not about GDSFactory or the Skywater PDK. This place is for the core application, these other projects are independent add-ons.
If you seek qualified assistance, you should go to these projects. I did not manage to get the gdsfactory PDK up and running myself, but the efabless one is working (https://github.com/efabless/sky130_klayout_pdk).
I assume the devices will receive some more development. For example, I don't know how to turn off the gate contacts and how to get a decent poly connection for fingered devices:
The steps it took me to install the efabless PDK are simple:
it is exactly that I want, I will try this
**Thanks **
I did what you said, I have no library skywater130 - sky130 Pce
If you have the data but it's not hooked up:
Tools>Manage Technologies
If you don't have the library data then hit up Skywater
or one of the open source fan clubs that surround the
foundry.
You can see the layout I made using OpenLane with a Verilog file on the Sky130 PDK. I installed OpenLane and completed it within a day. However, unfortunately, in one month,
I was unable to configure KLayout to integrate the library containing analog transistors
I wanted to say thank you for your response. Perhaps there is an impact as I am using Debian on a virtual machine.
It works
why I don't know !? I did the same thing again and again et voilà ...
Thank you very much for you help
