Given a Layout at: C\Users\whatever\layout.gds and creating a shortcut to it (Win: right-click -> create shortcut).
How can this shortcut be loaded?
path=r"C\Users\whatever\layout.gds"
# works
pya.Layout().read(path)
# does not work
pya.Layout().read(path + ".lnk")
The error I get is: RuntimeError: Stream has unknown format: ...lnk in Layout.read. Loading the .lnk file in KLayout GUI using File -> Open works fine however.
How can I load the shortcut in python similar to how it is done in the GUI?
Thanks! ![]()
Hi @Peter123,
I am sorry, but that is not supported natively.
Unlike Unix, on Windows, a link (*.lnk) is not handled by the file system, but by the shell. A "lnk" file is a binary file, nothing more, so an application needs to be coded in some special way to support it (see for example https://stackoverflow.com/questions/54728510/how-to-follow-a-symbolic-soft-link-in-cmd-or-powershell#54732814). Apparently, the "Open" dialog resolves the "lnk" file to the destination.
There is Python code available which resolves the links (https://github.com/strayge/pylnk/blob/master/pylnk3.py,
pylnk3module). You can copypylnk3.pyintoc:\users\your_name\KLayout\pythonto make this module available. There is no thing such as "pip" in a standalone KLayout installation.Matthias
Hello @Matthias,
Thank you for the info. I learned a new technique today
I found I should copy
pylnk3.pyintoc:\users\your_name\KLayout\lib\python3.11\.Kazzz-S
Hi @sekigawa,
That is interesting, but it is kind of unintended ... I need to check myself why this is working. It may depend heavily on Python internals which is not good as it would change with other Python versions
Hello @Matthias,
Oops, it's my mistake. My above description was incorrect. Sorry about that.
I placed
pylnk3.pyin the system's Python library, as shown below.I assumed
pylnk3.pyneeded to be treated as a part of the system's Python.I moved
pylnk3.pytoc:\users\your_name\KLayout\python($HOME/.klayout/python/ in the Linux|Mac env.).Then, it still works as you intended.
Thank you.
Kazzz-S
Ah, very good. That is what I was expecting!
Thanks for this confirmation.
