Total Thickness (finished thickness / substrate thickness / total substrate thickness)
Cu thickness (outer layer Cu thickness / inner layer Cu thickness / metal thickness / copper thickness)
Cu plating in hole (PTH Cu thickness / via wall Cu thickness)
Solder resist material (SR / Solder mask)
Solder mask thickness (SR thickness / SM thickness / Solder resist thickness / SRT)
Surface finish (Metal finish / finish / surface treatment)
Finished Bottom Width (Trace width / Trace / Width)
Finished Bottom Space (Trace space / Trace / Space)
Recessed Depth (RD / Recess depth)
Min Bump pitch (Bump pitch)
Finished Bump Bottom Width (Bump width / Bump pad size / Bump pad diameter)
Bump pad Opening Size (C4 Pad Opening Size / C4 SRO / Bump SRO)
Top via hole Size before plating (via diameter / top via diameter / drill diameter / BVH diameter)
Land Size (Via pad diameter / Via pad size / Via land diameter)
Via Cu dimple (Dimple depth / Via dimple)
Finished Bottom ball pad (BGA pad diameter / BGA pad size / Ball pad diameter)
SR CZ etching amount (CZ etching rate / CZ etch)
L1 metal space (L1 trace space / M1 trace space / L1 space / M1 space)
Could Klayout library help me extract these attributes ?
Example file is:
Hi @hieund,
No, KLayout cannot read DWG and extraction of texts isn't a core competence.
Maybe you can take a look into ezdxf (https://pypi.org/project/ezdxf/).
