I have found an issue in my Ipc2581 import script where I need to change specific drill hole shapes from one layer to another...
the location of these shapes are stored in the array _tmp_pts
Below is the new code I have developed:
    if _layname.match(/BACKDRILL_/)
      ### the next 4 lines don't work correctly...
      _view = RBA::LayoutView::current
      _view.each_layer do |_lref|
         _lref.visible = false
      #LayoutView::SelectionMode Reset
      #LayoutView::SelectionMode Add
      #_tmp_pts.each {|_pt|
      #    LayoutView::select_from(_pt, LayoutView::SelectionMode mode = Add)
      _sel = _lv.object_selection
      _sel.each do |_s|
          _s.layer = _drl_lay
      _lv.object_selection = _sel
      _tmp_pts.clear
         _lref.visible = true
Hi @mtnhomecad,
What exactly is the problem?
You mention that the 4 lines do not work. Does it mean that layer are not made invisible or visible?
I can't confirm this is not working.
I apologize for not including enough info for you to understand the issues I am seeing...
First - the screen capture of the Macro Development window below shows that when I continue the breakpoint at line 483 goes to line 491, skipping line 484:
Second - could you provide an script example of using
Lastly, what is the correct to change a shape's layer?
Below is my latest code, but fails at the layer assignment
Hi @mtnhomecad,
About the debugger: it should stop at 484, unless you do not have any layers in your view:
The "select_from" example is simple:
x and y are the coordinates where you want to select items from (in micrometer units).
And finally regarding the layer assignment: you can't change the layer of a shape. You need to move the shape from one "Shapes" container to the other:
BTW: why the leading underscores?
Thank you for the feedback, which was very helpful.
I just found a new issue where I need your advice:
I am getting the error: NoMethodError: undefined method `position' for #
however in the previous lines of code I have: if _ts.is_text?
A screen capture is shown below:
How do you delete Path or Text object from a script, since neither have a delete method?
The Shape class does not have a "position" method.
"Shape" is not a base class of "Text". Instead "Shape" is a generic shape. You can turn it into a Text object, and then use "position":
But this shortcut is faster:
The concept is explained here: https://www.klayout.de/doc-qt5/programming/database_api.html#k_8
To remove a shape from the database, use "shape.delete". The type of shape does not matter.
However, doing this during iteration is not safe - in particular not in viewer mode. The recommended way is to collect the shapes for deletion first and then delete them:
Per your feedback I updated the code to move the shape from one "Shapes" container to another and delete the original shapes afterwards:
The 'Macro Development Console' shows that the shapes were copied:
However the Layers tab in the resulting design shows the layer as being empty:
Do you any idea why this is happening?
I am not sure if you are using the layer numbers correctly. I don't see the whole script.
But here is a hint: "_drl_lay" has number 102, but it is not layer "102/0".
When you use:
then
_num_laycan be any number, KLayout assigns to layer "102/0". "102/0" is the database "name" (in GDS). In other formats, this "name" is not numeric, but a string. In OASIS for example, it can be both.So: if you want "_drl_lay" to be layer 102/0, then you have to use something like
Matthias,
Thank you for isolating the error in my code, per your advice it is working correctly now...
I also made another code change by changing the '-' characters in the layer names to '_' after getting errors when loading the generated netlist .l2n files, they load correctly now
