how can i change to blue font to some other color? i didnt found it in setup:
i cant read the blue font, but without problems the white one. the contrast of the blue is to small.
and how can i save the colors and stipples of the layers? if i change it, the changes are lost when i restart KLayout.
thanks a lot
then i have an other little question: is it intended that if i use the edit::selected::duplicate command, the selected layer is deselected? does it make sens in someway?
if You are routing some paths, and then duplicate and move one of it, and try to route further, You get an error message, and need to select Your layer again...
