Hello, is there a way to reverse or invert the tone of a GDS layout in KLayout Editor? So for example, if there is a layout with all polygons drawn to refer to a line, instead generate a layout with all polygons drawn to refer to the corresponding spaces. Thanks.
no, there is no such option yet. But you can invert a layout by using the "NOT" boolean operation. Draw a big rectangle covering your layout on a different layout and use "Edit/Layer/Boolean" to perform a "NOT" operation between the rectangle and the drawn layout (in Edit mode).
Currently, that method is confined to small and medium-sized layouts because of performance and memory reasons.
Painting in reverse tone is possible, but it's simply not implemented yet.
