DO you support path geometry with mixed path type, e.g., start extension type could be half-width & end extension could be variable.
I was trying to create a path of mixed path -type , but seems like the tool has some limitation to draw such kind of path.
path extension type : 00000110(0000SSEE)
I'd put two wires either overlaid (or divide the wire into two end-to-end contiguous wires), each one having a different end type.
Hi sapatra, hi David,
you could use "variable path extensions", for which you can specify start and end extension separately.
If you specify a start extension of 0 and an end extension of half the width you'll get exactly the 0110 extension type. That's a bit of an emulation, but this scheme covers the variants provided by OASIS.
