I'd like to create a keyboard shortcut for cycling between the erase/add combine modes
(accessible through the menubar otherwise).
For this purpose, I tried to create a python script along the following lines:
    win = pya.Application.instance().main_window()
    menu = win.menu()
    act = menu.action("@toolbar.combine_mode.combine_mode_erase")
    if act.is_checked():
      act = menu.action("@toolbar.combine_mode.combine_mode_add")
      act.trigger()
    else:
      act.trigger()
The "is_checked" function does not however work as I would like it to work.
Is there some other way to check what the current combine mode status is?
that's a configuration item embedded in the menu. It does not bind to an Action.
That's why you do it this way:
Values are:
addmergeerasemaskdiffMatthias
