Using KLayout 0.26.11 on Ubuntu 18.04, I am trying to run LVS with a netlist which has 3-terminal resistors, like so:
 r6 ground n015 ground  r=80k w=0.5u l=50.4u seg=4 m=1
When I use two-terminal resistor extraction as in
extract_devices(resistor("my_res_sab", 794),           {"R" => poly_res_sab, "C" => poly_not_res})
I get some device comparison results that look like this,
Objects                  ST    Layout               Reference
my_res_sab <=> GROUND    /!\   $180 / my_res_sab    3 / GROUND
with a warning about the device class mismatch and it seems the NetlistSpiceReader has interpreted the GROUND as the model name.
If I use three-terminal resistor extraction as in
extract_devices(resistor_with_bulk("my_res_sab", 794),          {"R" => poly_res_sab, "C" => poly_not_res,  "W" => bulk})
the devices won't be matched at all and there are two lines in the Netlist Database Browser (one for layout, one for schematic):
- <=> GROUND             (-)   /                    6 / GROUND
my_res_sab <=> -         (-)   $125 / my_res_sab    /
One more detail about the last result is that the netlist resistor is shown as a 2-terminal device, while the layout one as having 3 terminals.
Another experiment I did was to add the model name my_res_sab to the Spice netlist - but then the reader throws an error "Too many arguments for two-terminal device (additional argumen is 'MY_RES_SAB')" and I'm not even sure the netlist format allows for R devices with model names.
Is this behaviour expected? How can I get LVS to match?
Bearing in mind that I don't have much of any clue
about how to parse the given error reports...
... it seems to me that what's missing is the "capture"
of the parasitic substrate connection, the third terminal
(which in many PDKs has no ohmic connection, is only
a place to attach parasitic capacitance elements). The
two ends of the poly resistor should be found by the
logic involving contacts, and the parasitic node often
demands some recognition layer (e.g. "Bulk") that can
be logically mashed up with the poly polygon and
assigned for the resistor instance.
I recommend you pick apart that 3-terminal extractor
and find what it uses to recognize the substrate node
underneath the poly, and make sure the layout has
the objects the extractor needs to find.
Thanks for your comment @dick_freebird. What is interesting about the result I mentioned is that when I use the 3-terminal resistor extraction, the layout (extracted) netlist already has all three terminals A, B and W connected to the correct nets. Therefore I think (but might be wrong, as I am just starting with KLayout LVS) the problem might be in the SPICE netlist reader/interpreter... the fact that the 3rd terminal net (GROUND) of the SPICE netlist ends up being used as the model name (or as KLayout seems to call it, "device class") also is related to the netlist reader. Maybe I need to apply some options to the reader to make it understand 3-terminal resistors correctly?
I believe you can have resistors with or without a model
(certainly, without; forget the syntax for invoking a model
instead of the built-in primitive).
It might be that the schematic netlister needs to be
"educated" to get the format that works with LVS.
I have worked in a technology recently, where the
transistors normally are subcircuits including the
isolation junction parasitics and they have another
models-tree that is meant solely for LVS and omits
all the "gingerbread".
I'm more used to simple resistors (with perhaps
complex temp & geometry fit functions, but simple
arguments of ohms and centimeters) -
r1 1 0 1k tc1=xxx tc2=xxx
but this doesn't support LVS type-match because
it doesn't declare a type.
In the ngspice33 manual in the resistor section
is shown this example:
RE1 1 2 800 newres dtemp=5
where newres is the model. This appears in the fourth
argument position, so maybe your second GROUND -is-
being interpreted as a model.
It may be that the 3T resistor should be netlisted
as a subcircuit, where the third terminal has C/2
elements connected to the first and second.
But then you'd have even more elements to check.
For basic connectivity of explicitly placed devices
I think the parasitics should be dispensed with.
Unless you care where those parasitics' return path is,
like in RF. Then you do want the third terminal to be
explicit, and then dealt with. If the schematic netlist
incorporates those shunt-C parasitics then the layout
netlist must as well, or else they need to be "refined"
away.
I have tried to extract a resistor_with_bulk with an empty netlist. And ... KLayout extracts a resistor with only 2 terminals
Furthermore, if I try to add the reference netlist with a 3 terminal resistor, it complains that a resistor should only have 2.
I also could not find it in the documentation. Resistor and capacitor with bulk are often used in PDK, and especially in spice models file, BUT as a subckt, so the extraction syntax should be as sub-circuit : XR PLUS MINUS BULK R=1K RPOLY_SALICIDED
@cgelinek_radlogic : it is probably the syntax of your original netlist, is't it ?
BRgds,
Might be of some help
https://www.klayout.de/forum/discussion/comment/7484#Comment_7484
https://www.klayout.org/downloads/dvb/doc-qt4/manual/lvs_device_classes.html#h2-47
https://www.klayout.org/downloads/dvb/doc-qt4/code/class_DeviceClassResistorWithBulk.html
In order to connect the body of the resistor, you simply place it nearby a substrate connection (like the bulk connection of a transistor). You should not put the pdiff contact on top of the resistor, but somewhere next to it, dont worry too much about the distance you place it from the resistor, just make sure that it is far enough to prevent DRC errors, and obviously it should not be too far. Multiple resistors can share the same body connection. I would guess that the body should be connected to ground.
Dear all,
thanks for the discussion.
Actually, KLayout does not read three-terminal devices from Spice netlist. It's possible to extract devices, but how to describe them with the plain "R" syntax escapes me. You can model them as subcircuits though.
Maybe someone can enlighten me on the Syntax. My reference is ngspice which only has 2-terminal resistors.
There is
How will it be possible to introduce a third net without ambiguities?
BTW: the same is true for capacitors.
Hi everyone, thanks for your comments.
@laurent_c you're correct, one original netlist format is subcircuit-based as you said, but slightly different from your example:
As far as I understand (but haven't tried yet) the clean way to handle these in KLayout would be via the a custom NetlistSpiceReaderDelegate class.
In another technology, I have also seen the following format for 2-terminal resistors with model, not subcircuit based:
@Matthias, KLayout's netlist reader still doesn't understand this correctly as the value isn't simply a number but a parameter, though I could easily work around this using
gawkto pull the value out of the parameter and put it after the 2 terminals.Unfortunately, it seems like almost every technology/simulator/LVS tool seems to have its own format preference on how resistors and capacitors are represented, so maybe we'd need something a bit more flexible for parsing various formats.
I tried writing a custom NetlistSpiceReaderDelegate for the 3-terminal resistor, but the problem was that the NetlistSpiceReader threw an error because it didn't like that extra bulk terminal and didn't even attempt to call my NetlistSpiceReaderDelegate.
The only workaround I can currently think of is a combination of an external tool to transform the netlist (so it is accepted by NetlistSpiceReader) and a custom NetlistSpiceReaderDelegate to then translate this (new custom format) into a KLayout netlist, as follows:
valueout of a parameter likeR=value). If a 3rd terminal is present, make it a parameter, like$SUB=bulk(I have seen this format in one of the technologies we're working with).Once I've got a flow that works, I'll see if I can post it here.
@Matthias , next time you work on the NetlistSpiceReader code, may I suggest you consider whether it'd be feasible to change the logic such that a NetlistSpiceReaderDelegate controls whether the input format for a particular device is acceptable, rather than refusing to read the netlist altogether if it doesn't match any of the (hard) coded variants you mentioned above? This is just a low-priority suggestion because (as I said) this can probably rather easily worked around.
By the way, I really like the idea of having a something like NetlistSpiceReaderDelegate to control how a particular input case is handled... these design decisions are one of the things that make KLayout so attractive!
I believe two things want changed.
The schematic SPICE netlister needs to be "harmonized"
with whatever a "normal" layout might produce for
extracted device netlist lines. It would add a lot of
flexibility if you made all devices netlist to X (subcircuit)
abstraction layer under which you can manage multiple
"views" (content-versions) just by the include-chain -
one full parasitic detail, one for core device only that
LVS might like, one for general SPICE where the
simulator doesn't want to know from third terminals,
different xyzSPICE dialects, etc.
Now I am working in a JI technology and my Pbase
resistors sure do want to know where the TANK
potential is. That's a 3-terminal resistor with a
distributed junction diode. I think this once-common,
still-used layout object deserves an extractor if
indeed there is not one (?).
Thanks for your comments, they are very welcome!
Actually the intention of the ReaderDelegate wasn't to support any kind of Spice dialekt, but mainly to adapt X-based device models to one of the device models supported by KLayout.
I have created a ticket to track this issue: https://github.com/KLayout/klayout/issues/798. Please feel free to comment.
@dick_freebird Will the device extractor from https://www.klayout.de/doc-qt5/manual/lvs_device_extractors.html be sufficient for your application? It's taking two terminals and some resistor area in between which also renders the bulk terminal. Or will you need a separate bulk terminal?
Reviewing the doc link, I am a bit confused.
"For the resistor with bulk, the wire area is output on the "tW" terminal layer as the "W" terminal:"
is all that the resistor_with_bulk section declares (w/ pic)
but it is unclear to me how that "tW" layer may (or may not)
interact connectivity-wise with the actual bulk or diffusion
below. The description implies to me that this is a derived
layer created, rather than picking the existing layer in which
the resistor body is sunk. But maybe I am just confused
by the description.
For example (and this is common in old-timey JI linears
like LM-series) a Pbase resistor might be placed in a
TANK which is also the collector of a vertical NPN,
if that NPN has a convenient circuit connectivity.
Now will "tW" for the resistor somehow end up showing
connection to the NPN "C" terminal? And if so, how is
"somehow"? Is there perhaps a device-specific "connect"
statement needed, to connect tW to TANK for a Pbase
resistor, or tW to ISO for a Nemit resistor?
I need a bulk terminal which will establish the same
connectivity as the schematic; however I connect the
body terminal in the schematic, if the layout polygons
match that then so should the extracted netlist.
Here's a pic of what I'm wanting to address. This is
a TANK region which serves as collector for two
NPNs (with distinct B, E regions, Es wired together),
one lateral PNP and two distinct Pbase resistors.
The LPNP "B", VNPN "C"s and RPbase "tW" all need
to connect to, call out the same TANK region's
assigned node.
The foundry maintains two sets of SPICE "model
deck" - one with full junctions detail, which would
in this case demand some engineer "input" as this
is none of the single-device-models' but rather a
shared-bottom-plate structure, and one which
puts out only the "explicit" device which they use
special "recognition layers" to extract in poor-man's
Caliber (Tanner version). I'll be moving them off
that kludge, if I can. They share too many different
(say) NPN layouts into a single model with AREA=
for my liking; either use a true fitted geometry model
(which can never support the kooky you see here),
or do the work of maintaining model-per-layout and
then you also get to do symbol-per (not a big deal,
already well down that road).
@Matthias
Thank you so much for this, your proposed changes to the Spice reader would certainly ease the netlist preparation. This reminded me, another "feature" of many Spice netlists is the "line continuation" using the
+sign, like so:Again, easy to preprocess away, so just a suggestion.
@dick_freebird
I like you nice real silicon photos. Much better than polygons
I should explain what I mean by "tW": when KLayout extracts a device, it creates pins on layers you specify in the "extract_devices" call. This can be any layer, but it needs to become part of the connectivity so the pin gets connected. The lower case "t" stands for "target" and means this is a layer on which pins are generated. You don't need to specify such a target layer, but then KLayout will pick one of the inputs.
So in your case I assume you have some layer, e.g. "tank" describing the TANK area. I also assume you can identify some tap connecting to it. In CMOS, "tap" is something like "n+ AND n-well" or "p+ AND substrate". So the basic connectivity is something like:
You'll also need a resistor layer - maybe that is polysilicon. Often there is a marker on the resistor marking the resistive path but not the heads. So a typical expression is:
The resistor heads are still poly but outside the marker area. And we need to create a contact to them, so we can use:
to generate the connectivity for the head.
With this you can essentially use "tank" as target for the resistor's BULK pin and write the resistor extraction like this:
Note that I did not specify where the head pins go to (that would be "tC") - KLayout will put them on the "C" layer by default. This is poly_not_resistor and as this layer is part of the connectivity, the pins will get connected to these nets.
@cgelinek_radlogic You mean "+" isn't supported in Spice netlists in KLayout? I'm fairly sure it does already. Do you have a case where this does not work?
@Matthias
Hmmm, I just tried it and it did in fact work. Either I was looking at a different netlist (potentially yet another format), or I was still using KLayout version 0.26 ... either way, I'll let you know once I come across a problem like this again.
I just find that the proper syntax is :
This OK to check a resistor like : R0 1 2 GND RPolyRes_Bulk R=10k
But, how to check a resistor specified by its size : R0 1 2 GND RPolyRes_Bulk W=20u L=2u ?
BRgds,
I think there may be another "layer" behind this - what
of the case that the resistor's isolation is not "bulk" (i.e.
the P- handle / epi) but some other isolation region like
(say) a P+ resistor in NWell, or my above example of a
Pbase in a TANK which is the common VNPN collector,,
LPNP base as well? Does "_Bulk" have a hard-coded love
for "bulk" (as in nothing else applied), need a "bulk" layer, or
take the layer assignment from the "W" > (?syntax?) arg
despite the naming?
Geom args do want extracted / checked, and again these
may be properties / args of a subcircuit-style or maybe a
semiconductor-style resistor element but they won't be found
in simple SPICE primitives. Now, a design discipline for ICs
is that you don't put "generic" devices inside the chip design
(other than, in Cadence you might well place 'presistor'
out of analogLib, to make use of niceties like breaking a
schematic net for convenience, while allowing it to still
match a continuous layout net where no such element is
placed).
I believe the true right answer is for every process device
in the PDK (or what passes for on in a random collection
of point tools from SourceForge) to have a regularly formed
"subcircuit style" schematic/symbol which holds all the
"checkable" args for connectivity and attributes in the
invocation line, and not to use basic SPICE primitives in
the process libraries (though perhaps duplicating the
presistor, pcapacitor, pinductor duality would be handy,
and thin film resistors outside a RF application might do
without the substrate capacitance terminal - though then
you are making decisions about accuracy & completeness,
for a group of users, if indeed it's you deciding).
That's not necessarily something for the layout tool to
solve - it's a library developer's job, to "make it so". But
the layout tool -could- offer in its document stack, some
guidelines regarding "what works" (and what is known
to not) that a library developer or maintainer or upgrader,
could benefit by.
Sorry for the naming - "W" was intended to be "well" because my reasoning was that a cap/resistor would normally be biased against some isolation well (or substrate).
I agree with Jim - the Spice syntax (if there is something like a standard) is ambiguous with respect to defining 3-terminal devices for resistors or caps. A model subcircuit in the end is more versatile. However the implementation effort currently is considerable in KLayout as you need to define a Spice reader delegate to capture model subcircuits. That is flexible but ugly to code. There is room for improvement.
BTW: Is that just coincidence or is the same question asked here? https://www.klayout.de/forum/discussion/2095/capacitance-and-resistor-lvs-checks-ignoring-r-and-c-values#latest.
The original answer is given here: https://www.klayout.de/forum/discussion/comment/7990#Comment_7990. The mentioned post says it does not work. But no details. I have at least one working test case
Not sure about the bit regarding
"you need to define a Spice reader delegate to capture model subcircuits".
To me, all that it wants is to spit out an "X" element card,
rather than M/Q/D/R/C/? netlist lines. The subcircuit
definitions would be loaded in the "include-chain" setup
of paths / model .lib/.inc files, in the netlist or by manual
invocation?
What I believe is, any "technology" ought to have a rack of
extract rules for all technology supported devices. These
could point to a M(osfet) or an X (subckt) line with all the
same args harvested & lined up? But this is for the end user,
their "PDK developer" (if different) and the foundry source
of "Brand X" infrastructure (construction, rules, models,
maybe some rearranging to suit tool flow).
For my uses I would be looking to entirely substitute "X"
element cards for every legit device type, since I have a
need to emulate "external influences" that SPICE primitives
don't encompass in any case. So understanding how to
build that, is a "personal growth for someday" item....
Thank you Matthias, yep, it seems to be for the same process ... and it works fine ... my next step is to add the body pin.
 ! and the LVS is OK
@dick : the third pins is used to add the parasitic capacitance, and my case, yes, it the bulk
BRgds,
