Hi, Matthias!
I tried to make multiple screenshots after changing layers/group visibility in script. Looks like LayoutView.update_content
do not update view properly when group was not visible.
First screenshot taken for layer from visible group (Nested 1
) is fine, but second, for layer from invisible group (Nested 2
), is empty.
Script is:
main_window = pya.Application.instance().main_window()
current_view = main_window.current_view()
for index in range(1, 3):
suffix = f'{index}'
for layer_properties in current_view.each_layer():
layer_properties.visible = layer_properties.name.endswith(suffix)
print(layer_properties.name, layer_properties.visible)
current_view.update_content()
current_view.get_image(800, 600).save(f'Screenshot.{index}.png')
It was run with KLayout 0.28.11 with attached session/layout: klayout -u Session.txt -r script.py
Hi EugeneZelenko
Add a
process_events
beforeget_image
should able to solved this issueHi!
Thank your for help! It works!
But will be good idea to reflect this in documentation (
?).Dear all,
Wasn't that an issue before somewhere?
"process_events" is required as it triggers the repaint event that actually does the rendering.
But basically "update_content" could imply "process_events".
Thanks to the test case I could debug this issue and found a way to avoid the "process_events" call. This patch will be released in the next minor release. Even "update_content()" is no longer required.
Hi, Matthias!
Thank you for quick fix! It'll really simplify end-user code.
I believe so
It's actually released yesterday. There is some background processing happening and the single-threaded synchronous get_image etc. methods now take care of finishing these tasks before they deliver the image data.
Thanks for reporting the problem and the nicely prepared test case.
Hi, Matthias!
I tried to do such screenshots for multiple views opened in KLayout (with similar layer properties for each of them) and suggested workaround for 0.28.9 (
pya.Application.instance().process_events()
) and your fix in 0.28.12 work only for current view. As workaround I preserve current view, iterate through all views, set new current view, make screenshots and restore current view at the end.However, it's not obvious why
LayoutView.get_image()
behavior depends on view's activity status.Hi Eugene,
Thanks for bringing this up. I created a new ticket for this: https://github.com/KLayout/klayout/issues/1512
From the code perspective I think I understand why non-active views don't get updated. Maybe the following is a workaround:
Hi, Matthias!
Thank you for help! Probably, issue could be not of high priority, because two workarounds are available.
