I'm attempting to implement a PCell library which references itself to construct more complex PCells. In order to do that I need to populate the library without destroying it and rebuilding it since it would cause to unlink all existing PCells.
I achieved to do that by creating the library and using the Library reference instead of using the "self", but the library entries don't automatically refresh like it does when executing the regular self.register(xx)
I tried using self.refresh()
, lib.register(xx)
again, lib.refresh()
, updating the QWidget associated with the libraries, and there's no "library.unregister()"
function to try (actually nor "layout.unregister_pcell()" but there is "remove_technology"
. I guess library.delete() would be the equivalent).
The only solution I found was to switch the selected library view to the "Basic" one and then back.
Here's a sample:
import pya, os
import importlib.util as ilib
lv = pya.Application.instance().main_window().current_view()
wid = lv.widget()
widLib = lv.widget().libraries_frame()
def ezimport(filePath):
# Makes it less verbose to import modules found from the executing fileName
# → Script executed from a technology
extFilePath = filePath.split("/")
selfPath = os.path.join(os.path.dirname(__file__),*extFilePath)
spec = ilib.spec_from_file_location(extFilePath[-1], selfPath)
md = ilib.module_from_spec(spec)
spec.loader.exec_module(md)
return md
ent1 = ezimport("ent1_PCell.py")
ent2 = ezimport("ent2_PCell.py")
class NEW_LIB(pya.Library):
def __init__(self):
lib = pya.Library.library_by_name("NEW_LIB")
if not(lib):
# Set the description
self.description = "New Library"
self.register("NEW_LIB")
self.lib = pya.Library.library_by_name("NEW_LIB")
# Register PCells to the already existing NEW_LIB already exists
self.lib.layout().register_pcell("ENTRY1", ent1.PCell1())
self.lib.layout().register_pcell("ENTRY2", ent2.PCell2())
self.lib.register("NEW_LIB") # Only registers internally, won't update the library view
self.refresh() # Won't do a thing
lib.refresh() # Won't do a thing
wid.update() # Won't do a thing
wid.repaint() # Won't do a thing
widLib.update() # Won't do a thing
widLib.repaint() # Won't do a thing
NEW_LIB()
Thank you,
Gerard
I found another way to solve it (through the intended way).
Using
self.register()
by the end of the library class, and sendself
as a parameter for thePCell1
class (be it PCell2 is to be a child of PCell1). The child PCells would be registered inside the definition of the parent PCell class, so only the parent PCells are required to be registered explicitly in the library class.One thing I notice however is that the sub-cell name has the library repeated, and hiding the instanced PCell won't hide a standalone one.
Here's a simplified full code:
Hi @Tabra,
You can register multiple PCells per library.
Why not just doing:
So you just need to register in the proper order. If you delay the "pcell_id" calls to the point when you really need it (in produce_impl), you could even realize recursive dependencies. But I'd say that is bad style.
