Accessing "List of Landmarks" from Image import GUI
I am trying to write some script that automatically aligns user given (GUI) landmarks to a predefined set of markers in the design. However after browsing the image classes for a while, I couldnt find any way to access/retrieve the "List of landmarks" seen in the Image import GUI.
Does anybody know, whether this is possible and if so, how?
  • Nevermind, I just found the forum discussion about this exact problem xd.
    So there is still no solution to access them automatically?
  • No, there is not. Where did you find that mentioned?
    Landmarks in my perception are alignment helpers, but so far I did not consider them part of the display properties of an image.
    The only way to manipulate landmarks currently is to convert the image to a string using "str(image)" or "image.to_s", and manipulate the landmarks array there. The landmarks array is a somewhat stupid component:
    landmarks=[x1,y1,x2,y2,x3,y3,...];
    You can place it anywhere in the string - i.e at the beginning, but if you manipulate it, make sure you remove the original one.
