Bug report: Trying to insert Text on a hidden layer causes crash
I have recently come across a bug where if I try to insert text onto a layer which is currently hidden, the System gives me the bug report below.
In the past this has already caused the entire program to crash for me.
Here is the generated bug report:
Exception code: 0xc0000005
Program Version: KLayout 0.30.4 (2025-09-12 r8b0a8c731) AMD64
Backtrace:
0x7ffcced128c0 - (Qt5Core.dll) +2173120
0x7ffcceb0708d - (Qt5Core.dll) +28813
0x7ffcceb09eed - (Qt5Core.dll) +40685
0x7ffcceb0617d - (Qt5Core.dll) +24957
0x7ffcc32ff369 - (Qt5Widgets.dll) +979817
0x7ffcc33392b8 - (Qt5Widgets.dll) +1217208
0x7ffcc33656f9 - (Qt5Widgets.dll) +1398521
0x7ffcc336b363 - (Qt5Widgets.dll) +1422179
0x7ffcc32336ba - (Qt5Widgets.dll) +145082
0x7ffcc3234ed5 - (Qt5Widgets.dll) +151253
0x7ffcc32573d4 - (Qt5Widgets.dll) +291796
0x7ffcd5dfdea1 - (klayout_lay.dll) +581281
0x7ffcd5dfe629 - (klayout_lay.dll) +583209
0x7ffcc3f323d5 - (klayout_laybasic.dll) +664533
0x7ffcc3ea7822 - (klayout_laybasic.dll) +96290
0x7ffccedd43ab - (Qt5Core.dll) +2966443
0x7ffcc32141eb - (Qt5Widgets.dll) +16875
0x7ffcc3301615 - (Qt5Widgets.dll) +988693
0x7ffcc3301745 - (Qt5Widgets.dll) +988997
0x7ffcc33e960e - (Qt5Widgets.dll) +1938958
0x7ffcc3257a20 - (Qt5Widgets.dll) +293408
0x7ffcc3217dae - (Qt5Widgets.dll) +32174
0x7ffcc32200ba - (Qt5Widgets.dll) +65722
0x7ffcd5d8c934 - (klayout_lay.dll) +117044
0x7ffccece9038 - (Qt5Core.dll) +2003000
0x7ffcc321e00d - (Qt5Widgets.dll) +57357
0x7ffcc326dd1b - (Qt5Widgets.dll) +384283
0x7ffcc3270f37 - (Qt5Widgets.dll) +397111
0x7ffcd5d8c94e - (klayout_lay.dll) +117070
0x7ffcc3823784 - (Qt5Gui.dll) +276356
0x7ffcc37fcd6c - (Qt5Gui.dll) +118124
0x7ffcced445d8 - (Qt5Core.dll) +2377176
0x7ffcbf0cf505 - (qwindows.dll) +521477
0x7ffccece7374 - (Qt5Core.dll) +1995636
0x7ffccecefe65 - (Qt5Core.dll) +2031205
0x7ffcd5d92470 - (klayout_lay.dll) +140400
0x7ff60e921ad9 - (klayout_app.exe) +6873
0x7ffcd62814a2 - (klayout_rba.dll) +5282
0x7ffcc2bb4e4e - (x64-msvcrt-ruby310.dll) +2117198
0x7ffcc2bbfc6a - (x64-msvcrt-ruby310.dll) +2161770
0x7ffcc2bce364 - (x64-msvcrt-ruby310.dll) +2220900
0x7ffcc2bc0687 - (x64-msvcrt-ruby310.dll) +2164359
0x7ffcc2a310fd - (x64-msvcrt-ruby310.dll) +528637
0x7ffcc2a34eb5 - (x64-msvcrt-ruby310.dll) +544437
0x7ffcd6288345 - (klayout_rba.dll) +33605
0x7ff60e922619 - (klayout_app.exe) +9753
0x7ff60e923026 - (klayout_app.exe) +12326
0x7ff60e9212ee - (klayout_app.exe) +4846
0x7ff60e9213e6 - (klayout_app.exe) +5094
0x7ffdaab8e8d7 - (KERNEL32.DLL) +190679
0x7ffdab60c53c - (ntdll.dll) +574780
  • Hi @LeoTrois,
    can you give some details how to reproduce the problem?
    Here is what works for me for KLayout 0.30.5:
    1. Create a new, empty layout with layers 1/0, 2/0 and 3/0
    2. Make layer 1/0 the current one
    3. Hide layer 1/0
    4. Press the "Text" tool bar button to select text mode
    5. A warning appears saying that you are trying to place a text on an invisible layer
    6. Dismiss this warning
    7. Set text string as "ABC"
    8. Place a text by left-clicking somewhere in the layout window
    9. The same warning appears again
    10. Dismiss this warning
    11. Show layer 1/0
    12. The text appears where you have placed it
    Note if you place a single text only in a cell, it is not visible if you have turned on "lazy text rendering" on "Display / Optimization" in the Setup dialog.
