I would like to switch layouts but without losing the handle
I have the following example code:
mw.create_view()
ly1 = pya.Layout()
ly1.read( "design1.oas")
ly2 = pya.Layout()
ly2.read( "design2.oas")
mw.current_view().show_layout(ly1, False)
mw.current_view().show_layout(ly2, False)
on the last line I am getting the error: Object has been destroyed already for argument #1 ('layout') in LayoutViewBase.show_layout
I understand from it that layoutview.show layout is then destroying the previous design
is there a way to switch layouts views without destroying them?
No, there is no such switch. Currently, "show_layout" will pass the ownership over the Layout object to the view.
But you can pass a copy:
If that is deleted, your original layout is left intact. But the copy and your original layout are detached. Still it's an option to display a layout object.
Thanks, I then rather went for the duplicate before the switch. ie:
Hi @jonathan,
That's also an option.
If you like, you can raise a ticket on GitHub. I think your request is reasonable, it's just not supported yet.
It will just be a separate class, so a kind of layout wrapper.
I have only used Gitub once in the past. I have raised an issue: If it is done wrong or any other problem, let me know.
in any case no big issue: the solution above works really well and after using it I do not see any performance issue.
Thanks for the support!
Thanks, but where did you create it?
The issue space for KLayout is here: https://github.com/KLayout/klayout/issues
You can refer to this discussion. GitHub tickets are a good way to publicly discuss topics and refer to them in release notes.
Hi, I created the issue in KLayout/klayout
here is the link to the issue:
https://github.com/KLayout/klayout/issues/2243
I can however not see it listed in KLayout/klayout/issues
But I do not know what I am doing wrong.
Maybe I need some approval that it is not spam?
Sorry for being quite ignorant there.
I don't see it either .. It says 404 for the link you pasted.
I created one for you: https://github.com/KLayout/klayout/issues/2248
