Hope you are doing well,
In the context of gf180, I've been experimenting with DRC, how to make it faster and improve quality of life from a GUI user point of view.
My initial issue was the speed of the DRC deck. For a somewhat simple full chip design, deep DRC, I was getting run times of more than 20 minutes on my beefy computer when starting the DRC from the GUI.
I knew that there should be some way to improve this, because CPU utilization was generally low, albeit with some large spikes. That gave me the feeling that the process was memory-bound instead of cpu bound.
The gf180 pdk (same with IHP) also provides a python utility, where each file was run in its own klayout process. This considerably improves speed (~5x), but suffers from a few issues:
1) Each run generates its own reports, checking for DRC clean is a nightmare
2) General layers have to be recomputed each time. While this does not always result in longer run time depending on number of cores, it is a certain limitation. Moreover, the general layers are duplicated in ram for each process, causing a larger memory usage.
I've experimented a bit and implemented my own DRC approach to try and solve both issues. It is implemented fully in ruby using forks, and has great performance (similar performance as the python script with untapped potential and less RAM usage).
Here are the currently issues preventing it from being merged to upstream PDK
Due to something in QT/graphics driver panicking when joining threads in GUI, I have to run the forking script in a klayout batch mode process. This means that (1) the project has to be saved to disk before running DRC, but more importantly that (2) there are currently no way of canceling a DRC run from the GUI.
(2) is because it seems there are no cancel flags exposed from the C++ to ruby API. From my understanding, the cancel action causes the C++ side DRC calculation function to throw an exception, which is caught from ruby. In my case, I do not think I can use this approach in a clean manner.
My first issue with drc reports is that there is currently no way of obtaining one without creating a file. That means that in case of parallel DRC runs, I have to create one temporary file per run, which is not so clean. I implemented a basic functionality allowing to get reports as a string rather than a file here, but I don't think it is very good. I then reverted to using files.
My second and bigger issue is that there is no way of merging report files together, so that it is presented cleanly in the GUI report view. In the present case, we only need a simple approach, as we are guaranteed that the top cell of all report files is the same. I've implemented this outside klayout here. Beware, that specific part is mainly AI (goal was proof of concept).
Do you think that this approach to DRC is sane?
How would you see the cancel functionality implemented? Is there some way I did not think of, or new functionality is need on the klayout side?
Same thing with the report file merging. If you guide me a bit (where to implement this function), I could try to make an MR.
Hi @Scafir,
I'd not try parallelization inside the application. Qt and large parts of the application are not thread-safe. You need to provide strict thread isolation and there are too many side effects beyond your control. Specifically I don't trust the script engines and the native modules involved. A single breach in thread safety will give you bugs that happen rarely and are extremely difficult to debug.
I think the safest approach is to split the job into subprocesses and join the results. I don't understand what is so bad about files. After all, that's still the most reliable and portable way to exchange information between subprocesses. Threads are fashionable, but the sharing of memory creates too many issues and I don't want to waste my time with hunting rare glitches. A subprocess is easy to kill.
But I think you'd need some kind of DRC dashbord - some UI that shows the running subprocesses and their status and has a kill button to stop all these subprocesses. At least that's how I would envision some farm-enabled DRC.
Merging of DRC reports: there is no single function to do that right now, but the report database has an API, so it should be possible to do the merging in a script. But a merge feature is an enhancement worth considering. There is a method called "apply" which is doing some attribute merge, but it's intended to applying waiver flags from a waiver database.
A general note aside: DRC performance can usually be optimized significantly be rearranging the DRC deck and using alternative implementation options. GF180 suffered from some issues initially and I can't say if all my suggestions where implemented. I'm willing to take a look, but I'd need the (preferably large) sample layout and a pointer to the current GF180 deck. For me that's also an opportunity to optimize the engine. Right now, it is not strong in parallelization and have a bad core utilization usually.
Hi @Matthias ,
Thanks a bunch for the answer.
The files are not a big issue indeed. I wanted to mention it, but no need to discuss it further.
To be clear: what I've implemented does not do shared memory, locks, ... I'm forking, hence creating separate subprocesses, and I collect the files after the child processes are complete. Though now, I know understand the issue with QT/Graphics, as even though the memory is separate, the file descriptors are not.
I quite like the forking approach though, because in my benchmark, I could get more than 2x improvement in ram usage compared to fully separated processes (due to Copy on Write). This is likely because the general layers computed initially are quite large. I'm unsure if forking within a batch klayout process would reduce the risk to an acceptable level though..
Having a UI element tracking the different workers would be awesome, but I wouldn't know where to even begin for such an implementation.
It's indeed possible to merge the reports in a script, but if this would be integrated within klayout, would you see it implemented in the ruby or c++ side?
As I am quite new to the open pdk ecosystem and GF180, I also have no idea about the implementation of your suggestions. There's currently improvements to the DRC scripts that are being upstream (mostly to better match the gf180 specs). There are also ugly things still like the density and antenna checks being processed completely differently from the rest of the deck.
If you would like to take a look, you could use the wafer space pdk (the changes there are the one being upstreamed):
https://github.com/wafer-space/gf180mcu
Concerning the designs, mines are large but very empty. Still, they take quite a long time on a single core:
The filled one takes a lot longer, I suspect this is mostly due to the offgrid checks.
You can also find other designs, all of which are open and being manufactured here:
https://github.com/wafer-space/ws-run1/
Best,
Clyde
Hi @Scafir,
thanks for the pointers. I will take a look. I just can't promise a swift response. Performance issues are usually ugly to trace back.
Hi @Matthias ,
My pleasure. No pressure on the swift response, you're pulling a lot of weight already.
I might do a couple ugly things to get the cancel functionality to work on my parallel implementation, but I will make sure the vanilla, single threaded approach still works and is accessible easily.
I am trying to reproduce the run.
Variant "A" wasn't working for me, as the slotting rules need metal5, so I am picking variant "C". But even without, almost all time is spent in the "netlist" step.
There was a ticket recently where Leo mentioned an issue with "netlist": https://github.com/KLayout/klayout/issues/2241#issuecomment-3618509131. The problem there was a bug in the connectivity which essentially turned the chip into a big short.
The way I run the DRC is this:
It pulls the connectivity from "rule_decks/main.drc", which has the bug mentioned in the above GitHub ticket. On the other hand there is "gf180mcu.drc" which does not have this bug and uses "ncomp_not_poly" for connectivity.
So I'm a little confused. What is the right way to run the DRC?
Hi @Scafir,
I made a lot of progress here.
First, a general problem was related to netlist performance, which degraded in 0.30.6. It's addressed by https://github.com/KLayout/klayout/issues/2277, which brings down the netlisting times considerably.
Netlist performance also suffered from a connectivity bug: the comp needs to be cut by poly before participating in the connectivity. See my patch here: https://github.com/klayoutmatthias/gf180mcu/commit/0ce3e15f164c58cbabdc5b3b0a1d2088ee36b01f
I also improved performance of the mslot implementation: when you first pre-select large features before you subtract the vias, you do not need to handle polygons with tons of holes. See patch here: https://github.com/klayoutmatthias/gf180mcu/commit/2fb81fe2a7a2d8231bd656f40edbf760cb6362cb
With these changes, I brought the runtimes on the non-filled case down to 1352s with default number of cores (2).
I implemented some optimizations, specifically for multi-threaded "enclosed", which brings this runtime down to about 1000s. One problem was a strange case of thread synchronization which rendered use of multiple cores inefficient. Now, at least in some places, multi-threaded features benefit better from multiple cores, but it will not scale significantly.
I also implemented a RDB merge function that I think you will find helpful to merge the results (see here: https://github.com/KLayout/klayout/commit/992947f748ac1acec33303aa0ccc92f3f9915660).
Most of that is in the "wip" branch which I will merge soon and release in the 0.30.7 version.
Thanks and best regards,
