Reader LEF/DEF
edited December 2009 in File Formats
Christmas is coming soon...
So, one thing which will be helpful, its a reader of LEF/DEF.
In a 1st step, the LEF reader, like that we will can easely verify our LEFs
I think that this topic goes w/ the other one: GDS to LEF.
Joaquim
    Hi Joaquim,
    I received that request already a couple of times.
    However, I am lacking a good example currently. Do you have a link to a public source of LEF/DEF sample files?
    for the specifications of the format (they have also a LEF/DEF Toolkit but I don't know really if you can use it):
    http://www.si2.org/openeda.si2.org/help/group_ld.php?group=6
    for a free library (you have to register but its free):
    http://www.nangate.com/index.php?option=com_content&task=view&id=137&Itemid=137
    if you need some others LEF examples or if you have questions, you can send me directly a mail if you want.
    Joaquim
  • edited December 2009
    Thanks for the links. I'll have a look.
  • edited January 2010
    Will be good!
    Now I'm using simple ruby script (not universal but enough for my purposes).
    1. I run 'klayout -r script.rb';
    2. File -> Open LEF
    Script below (only for LEF observing)
    Thanks. Sergey.
    <pre>
    # Ruby file for KLayout for work with LEF.
    # klayout -r LEF.rb
    $app = RBA::Application.instance
    $mw = $app.main_window
    class MenuHandler < RBA::Action
    def initialize( t, k, &action )
    self.title = t
    self.shortcut = k
    @action = action
    def triggered
    @action.call( self )
    private
    @action
    class LEFCell
    def initialize(macro)
    @name = macro
    @bb = LEFRect.new("prBoundary", 0, 0, 0, 0)
    @pins = Array.new
    @obs = Array.new
    @cell = $layout.add_cell(@name)
    def render
    @bb.draw
    @pins.each { |pin|
    pin.draw
    pin.label
    @obs.each { |blockage|
    blockage.draw
    def name
    return @name
    def pins
    return @pins
    def obs
    return @obs
    def cell
    return @cell
    def bb(rect)
    @bb = rect
    return @bb
    class LEFRect
    def initialize(layer, x1, y1, x2, y2)
    @layer = layer
    @rect = RBA::DBox.new(x1, y1, x2, y2)
    def draw
    @layer_id = 0
    @layer_tmp = @layer + ":bnd"
    if defined? self.name
    @layer_tmp = @layer + ":net"
    @layer_id = $lid[@layer_tmp]
    if ! @layer_id
    @layer_id = create_layer(@layer_tmp, 0x000000, 0x0000ff, 1)
    @intbox = RBA::Box.from_dbox(@rect)
    $layout.cell($cell).shapes(@layer_id).insert_box(@intbox)
    def layer
    return @layer
    def rect
    return @rect
    class LEFPin < LEFRect
    def initialize(name, box)
    @name = name
    @box = box
    @layer = @box.layer
    @rect = @box.rect
    def label
    @orig = RBA::DTrans.new(@rect.center.x, @rect.center.y)
    @text = RBA::Text.new(@name, RBA::Trans.from_dtrans(@orig))
    # if @name =~ /vdd/
    # print "vdd ", (@rect.center.x/1000).to_s, " ", (@rect.center.y/1000).to_s, "\n"
    # end
    # if @name =~ /vss/
    # print "vss ", (@rect.center.x/1000).to_s, " ", (@rect.center.y/1000).to_s, "\n"
    # end
    @layer_id = $lid["text:net"]
    if ! @layer_id
    @layer_id = create_layer("text:net", 0xffffff, 0xffffff, 1)
    $layout.cell($cell).shapes(@layer_id).insert_text(@text)
    def name
    return @name
    def get_layers
    if ENV['lvlyp']
    f = $cv.load_layer_props(ENV['lvlyp'])
    l = $cv.begin_layers
    while ! l.at_end?
    l.current.name =~ /^\s*(\S+)\s*/
    $lid[$1] = l.current.source_layer_index(0)
    l.next
    def create_layer(name, frame, fill, stipple)
    $lid[name] = $layout.insert_layer(RBA::LayerInfo.new)
    ln = RBA::LayerPropertiesNode::new
    ln.name = name
    ln.dither_pattern = stipple
    ln.fill_color = frame
    ln.frame_color = fill
    ln.width = 1
    ln.source_layer_index = $lid[name]
    $cv.insert_layer($cv.end_layers, ln)
    return $lid[name]
    def parseLEF(lef)
    cellList = Array.new
    cell = 0
    layer = ""
    rect = 0
    pin_name = ""
    flag = 0
    macro = 0
    coeff = 1000
    x1 = 0
    y1 = 0
    x2 = 0
    y2 = 0
    x_origin = 0
    y_origin = 0
    lef.each { |line|
    case line
    when /^\s*DATABASE\s+MICRONS\s+(\d+)/
    coeff = $1.to_f
    flag = 0
    when /^\s*MACRO\s+(\S+)/
    macro = LEFCell.new($1)
    cellList.push(macro)
    flag = 0
    when /^\s*FOREIGN\s+\S+\s+(\S+)\s+(\S+?)\s*;/
    x1 = $1.to_f * coeff
    y1 = $2.to_f * coeff
    flag = 0
    when /^\s*ORIGIN\s+(\S+)\s+(\S+?)\s*;/
    x_origin = $1.to_f * coeff
    y_origin = $2.to_f * coeff
    flag = 0
    when /^\s*SIZE\s+(\S+)\s+BY\s+(\S+?)\s*;/
    if macro != 0
    x2 = $1.to_f * coeff - x_origin
    y2 = $2.to_f * coeff - y_origin
    macro.bb(LEFRect.new("prBoundary", x1, y1, x2, y2))
    flag = 0
    when /^\s*LAYER\s+(\S+?)\s*;/
    layer = $1
    flag = flag & 3
    when /\s*RECT\s+(\S+)\s+(\S+)\s+(\S+)\s(\S+?)\s*;/
    rect = LEFRect.new(layer, ($1.to_f * coeff), ($2.to_f * coeff), ($3.to_f * coeff), ($4.to_f * coeff))
    flag = flag | 4
    when /^\s*PIN\s+(\S+)/
    pin_name = $1
    flag = 1
    when /^\s*END\s+(\S+)/
    if $1 == pin_name then flag = 0 end
    when /^\s*OBS/
    flag = 2
    when /^\s*END\s*$/
    if flag == 6 || flag == 2
    flag = 2
    elsif flag == 5
    flag = 1
    else
    flag = flag & 3
    # print flag.to_s, " - ", line
    case flag
    when 5
    pin = LEFPin.new(pin_name, rect)
    macro.pins.push(pin)
    # print pin_name, "\n"
    when 6
    macro.obs.push(rect)
    return cellList
    def openLEF
    $clv = $mw.create_layout(0)
    $cv = $mw.current_view
    $layout = $cv.cellview(0).layout
    $lid = Hash.new
    get_layers()
    file = RBA::FileDialog.get_open_file_name("Open LEF", ".", "LEF File (*.lef *.plef)")
    if file.has_value? == false
    return
    lef = IO.readlines(file.value)
    $cellList = parseLEF(lef)
    $cellList.each { |item|
    $cell = item.cell
    item.render
    $cv.select_cell_path( [$cell], 0 )
    $cv.zoom_fit
    $cv.max_hier
    menu = $mw.menu
    $open_LEF = MenuHandler.new("Open LEF", "Ctrl+Shift+L") { openLEF }
    menu.insert_item("file_menu.#2", "rba_test", $open_LEF)
    $app.exec
    </pre>
    I'm not a ruby programmer, so ... But it works!
    How to format code?
    I have a problem with "Markdown" radio button.
    Thanks. Sergey.
    Hi Sergey,
    Thanks for providing the script. Great job!
    Since I think it's useful for many users, I have (hopefully) restored the formatting and put it on the server. It can be downloaded here: LEF.rb.
    BTW: "Markdown" is one of those Wiki-style plain text markup languages. It's documented here. Code formatting can be achieved by indenting with 4 spaces.
    Hi All,
    the script works very well.
    I would like to define a different color for each lef-layer when I read the .lef.
    How can I do?
    thanks,
    Salvatore
    ...other question..
    Some of my pins aren't define as RECT but :
    PIN A
    DIRECTION INPUT ;
    USE SIGNAL ;
    PORT
    LAYER M1 ;
    POLYGON 0.140 0.980 0.255 0.980 0.255 1.710 0.140 1.710 ;
    END
    END A
    In the Lef.rb script the POLYGON case doesn't exist.
    How to draw a polygon?
    Salvatore
    Hi Salvatore,
    You can specify a layer properties file to use with the LEF import script by defining an environment variable named "lvlyp". The values of this variable should be the absolute path of a layer properties file. This file will be loaded when the LEF file has been imported.
    Regarding the POLYGON problem I changed the LEF.rb script so it supports these shape types as well. I hope I didn't spoil it.
    thank you, now it works for the POLYGON too but only if the POLYGON definition is on the same line
    of the .LEF.
    For example :
    PIN vdd
    DIRECTION INOUT ;
    USE POWER ;
    SHAPE ABUTMENT ;
    PORT
    LAYER M1 ;
    POLYGON 0.000 2.240 0.610 2.240 0.610 1.640 0.730 1.640
    0.730 2.240 1.945 2.240 1.945 1.610 2.085 1.610 2.085 2.240
    3.325 2.240 3.325 1.600 3.455 1.600 3.455 2.240 3.800 2.240
    3.800 2.800 0.000 2.800 ;
    END
    END vdd
    In this case the POLYGON end (;) is on a different line and so it doesn't work.
    Salvatore.
    Hi Salvatore,
    I tried to fix the script accordingly. Hopefully it's working now. The download link is the same than before (LEF.rb).
    great! It's working. But there is a last issue :
    - the pin name label position is in the center of the polygon boundary box so sometime it isn't over the pin polygon.
    Thank you for your support.
    Salvatore
    Hi Salvatore,
    I tried to fix that issue by using the leftmost bottom point and putting a text close to this point (displaced by 5 DBU's). I hope that is a useful heuristics to provide a point "inside" the polygon.
    I replaced the file already. The download link remains the same.
    Great script ! I have slightly modified the LEF.rb script to map the LEF layers to GDS metal layers.
    I now want to load the default "layer properties" as specified in the setup. What is the ruby code to load the default layer map file ?
    Nick
  • edited March 2010
    Hi Nick,
    I have not tested it myself yet, but this code should work:
    def get_layers
      lyr_file = RBA::Application.instance.get_config("default-layer-properties")
      if lyr_file != ""
        f = $cv.load_layer_props(lyr_file)
        while ! l.at_end?
          l.next
    A more elaborate version should do some more error checking and try to resolve relative paths.
    It works perfectly ! Many many thanks. If you want the new code feel free to contact me.
    Nick
